8
Battery saving mode?
Would you like to have a battery saving mode in your OPO?
  1. Yes, it'd be nice
    90.8%
  2. I don't care
    7.2%
  3. It is just stupid
    1.9%
  1. adaita
    Froyo Jul 18, 2014
    adaita , Jul 18, 2014 :
    Well, battery saving mode on GS5, Sony Stamina mode does bit more than reducing brightness, cpu mhz and wifi/data/background sync. They also reduce display frame rate which helps extend battery time significantly! I haven't found any app that can do that on CM roms just yet.
    #41
  2. r0ssr0ss
    Eclair Jul 18, 2014
    r0ssr0ss , Jul 18, 2014 :
    go to about phone, tap build over and over until developer options are enabled, then in settings at the bottom there's a performance menu added. you can set to perfomance, power saving or between. you can also underclock the phone to save a lot of battery if you're not using anything that demands lots of CPU power.
    #42
    sbenson likes this.
  3. xXghostXx313
    Donut Jul 18, 2014
    xXghostXx313 , Jul 18, 2014 :
    When android L is release battery life will increase with art instead of davik. Also isn't there a built in battery saver in the new Android L ? I can't remember
    #43
  4. Anaron
    Gingerbread Jul 18, 2014
    #44
  5. trechoy
    Ice Cream Sandwich Jul 18, 2014
    trechoy , Jul 18, 2014 :
    When my battery goes under 20%, I always just go into Settings>Performance. I change the profile to "Battery Saver" and I put the Max. Frequency down to 1.2 GHz.
    #45
  6. Bigrich0272
    Bigrich0272 , Jul 18, 2014 :
    As long as I can make it thru the day with out charging I'm happy I throw mine on every night when I go to bed and it usually last me all day long I get home and still have 35% and I'm on my phone all day
    #46
  7. robgarth
    Cupcake Jul 18, 2014
    robgarth , Jul 18, 2014 :
    Bettery saving mode seems a little pointless. With the toggle switching in the notifications tray in cyanogenmod you get effectively the same thing, and finer control.
    Turn off GPS, Lower brightness, WiFi/Data off if you're not using them, hey presto! Battery saving.
    #47
  8. jizang
    Lollipop Jul 18, 2014
    jizang , Jul 18, 2014 :
    there is a performance option where you can choose from 3 profiles - power save, balanced and performance. I presume if you choose power save, this will save some battery power. very similar to custom kernals
    #48
    robgarth likes this.
  9. vassy.uk
    Jelly Bean Jul 18, 2014
  10. robgarth
    I forgot about the kernel scheduling. Though in my experience it makes your phone really sluggish.
    #50
  11. kaedee
    kaedee , Jul 18, 2014 :
    with the battery inside you should never need a battery extender mode. I have yet to finish the day with less than 20% and I am mid to high user
    #51
  12. jvkeizer
    jvkeizer , Jul 18, 2014 :
    I have the Android L preview on my Nexus 7 and I like how you can set a battery level at which it will change to battery saving mode which will turn down your brightness and turns down the clock speed of your cpu I think (it turns down performance). As the OnePlus One will be getting Android L when it comes out, it'll surely get that feature too.
    #52
  13. ismet
    Ice Cream Sandwich Jul 19, 2014
    #53
  14. Radeon962
    KitKat Jul 19, 2014
    Radeon962 , Jul 19, 2014 :
    Battery life so far exceeds anything I have owned including the Note 3 so no need for battery saving for me. OP has been providing about an extra hour of screen on time as compared to my Note 3.
    #54
  15. youdoofus
    Cupcake Jul 19, 2014
    youdoofus , Jul 19, 2014 :
    Its just a software tweak, so if CM decides that its a good feature for its OPO users, then itll be in there
    #55
  16. domi39
    KitKat Jul 19, 2014
    domi39 , Jul 19, 2014 :
    there is a battery saving mode
    #56
  17. hhh44
    Froyo Jul 19, 2014
    #57
  18. Boutchoo
    Gingerbread Jul 20, 2014
    Boutchoo , Jul 20, 2014 :
    Even if the phone as a 3'100 mAh battery, when you are in an adventure slaying dragons, you don't always think to bring a cable/wall plug...
    #58
  19. mingtrinh
    Ice Cream Sandwich Jul 20, 2014
    mingtrinh , Jul 20, 2014 :
    Are you saying this Flagship Killer doesn't have battery saving mode?
    Bit silly to not have this feature on any phone :)
    #59
  20. Paulisan
    Paulisan , Jul 20, 2014 :
    There IS something like a battery saving mode. You can activate it in the tiles. Then you can switch between Max. Performance, Battery Saving and Balanced.
    But I don't know what's really changing since I have the phone just for two days and still plying around with it.
    #60
    mingtrinh likes this.
