8
Battery saving mode?
Would you like to have a battery saving mode in your OPO?
  1. Yes, it'd be nice
    90.8%
  2. I don't care
    7.2%
  3. It is just stupid
    1.9%
  1. syd_xp
    Cupcake Oct 13, 2014
    #81
  2. browney
    Eclair Nov 15, 2014
    browney , Nov 15, 2014 :
    Although the battery is great I too feel that a battery save mode (much like the one found in the m8) would be nice. I always find using auto-brightness on my oneplus means the screen is often too bright (I know you can change this in settings)
    #82
  3. ajithkjm
    Cupcake Dec 4, 2014
  4. spongemike
    Gingerbread Dec 4, 2014
    spongemike , Dec 4, 2014 :
    I want it.
    The reason for me is to control what apps can have access to use data. On my Sony Xperia Z3 compact when I turn on the stamina mode it allows me to chose which app have access to use data when the screen is off. This feature alone makes it worth it because I only enable a few apps to have access the data and block the rest.
    I don't not want any apps in the background sending info out or my location (looking at you google play service)..
    #84
  5. TigerXC
    Lollipop Dec 4, 2014
    #85
  6. schleppy
    schleppy , Dec 4, 2014 :
    Yeah, this is built into the phone already. Just go into setting and then performance. You can also enable a quick toggle that lets you cycle between Power, Balanced, and Battery Saver mode.
    #86
  7. Shivaji Jarabala
    Froyo Dec 4, 2014
    Shivaji Jarabala , Dec 4, 2014 :
    Its available already... Go to notification tiles bar.. Click add tiles and u can see in the menu add it... Screenshot_2014-12-05-03-44-49.png
    #87
  8. DowntownJoe
    Honeycomb Dec 4, 2014
    #88
  9. durismichalto
    Donut Dec 5, 2014
    durismichalto , Dec 5, 2014 :
    You can lower max. frequency of processor for the power saving just right now. You can find in settings.
    #89
  10. DowntownJoe
    Honeycomb Dec 5, 2014
    #90
  11. JAISONGURU
    Gingerbread Dec 5, 2014
    JAISONGURU , Dec 5, 2014 :
    Yes..it can happen in any unforseen situation and you are away from a power source for a long time then it is always good to have a power save function
    #91
  12. mriganksinha
    #92
  13. goldenstang
    Donut Dec 24, 2014
    goldenstang , Dec 24, 2014 :
    The 1+1 gets excellent battery life, but for the situation where you can't charge overnight and really need to keep you phone alive for calls and text then a battery saving mode similar to the GS5 would be excellent.
    #93
  14. lokesh.zende
    Cupcake Apr 10, 2015
    #94
  15. lostLambda
    Lollipop Apr 10, 2015
    #95
  16. Skf123
    Marshmallow Apr 10, 2015
    Skf123 , Apr 10, 2015 :
    Lol u trollin?
    #96
