Battery slow to charge between 90 and 100% via OnePlus 8 Pro
  1. misteurz
    Froyo May 19, 2020
    misteurz , via OnePlus 8 Pro , May 19, 2020 :
    Hi,
    My Oneplus 8 Pro is really slow to charge between 90 and 100%?
    With the official cable and official power supply of course.
    What about yours?
  2. Max_Fremps
    Gingerbread May 19, 2020
    Max_Fremps , May 19, 2020 :
    It's normal, speed up at low battery % and then it decrease so it won't danger the battery
    GSVTech likes this.
  3. misteurz
    Froyo May 19, 2020
    I know every phone slows down charging when it's nearly full, but on my Oneplus 8 Pro, it seems really slow at the end ...
    I'll time it on next charge
  4. misteurz
    Froyo May 19, 2020
  5. Colinm428
    Honeycomb May 19, 2020
    WuTang and GSVTech like this.
  6. GSVTech
    Froyo May 19, 2020
  7. Lavin A.
    OnePlus Accessory Tester May 19, 2020
    Lavin A. , May 19, 2020 :
    The charge rate will slow down after 85% to prevent battery wear, it's the same across all OnePlus devices.
  8. ExterminalPT
    Froyo May 19, 2020
    ExterminalPT , May 19, 2020 :
    You are right, but not only in OnePlus. ALL devices from ALL brands do this to prevent battery wear.
  9. Ronnie2020
    Froyo May 21, 2020
    Ronnie2020 , May 21, 2020 :
    FYI - You will see even more time needed to complete the last lap if you're using OnePlus wireless charger. At times this can be annoying, but guess it's needed for the long term health of the battery, as others have pointed out above.
