Battery/Charging Battery Temperature too low, cannot charge! OP5
  1. pathaksummit Eclair Dec 17, 2018
    pathaksummit, Dec 17, 2018 :
    My OP5 suddenly turned off at 50% battery.
    when I try to turn it on, it says: battery too low, charge for a while before power on.
    when I plug in charger (original charger) it says: Device temperature too low. Cannot charge
    workaround: turn on the phone multiple times while charging. the phone will eventually turn on and stuck on 50% battery. when I unplug the charger the phone turns off after a few minutes.
    P.S.: I'm on beta version and recently, upgraded it to Android Pie beta version and after the update my device sometimes freezes and need to hard power off to get back to normal.
    G1547221935104 likes this.
  2. the_o2 Lollipop Dec 17, 2018
    the_o2, Dec 17, 2018 :
    Hope it's not a hardware issue, which is most probably looks like
    Try as this thread suggest, the battery calibration part
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    Meanwhile report this here
    https://forums.oneplus.com/feedback
    pathaksummit likes this.
  3. G1547221935104 Cupcake Jan 11, 2019
  4. G1547221935104 Cupcake Jan 12, 2019
    G1547221935104, Jan 12, 2019 :
    Ich habe folgendes herausgefunden.
    Die Akku-temperatur liegt bei "-40°C", das liegt daran, dass der Akkusensor kaputt ist.
    Doch wie man den Reparieren kann, werde ich nicht beantworten können, würde es aber selber gerne wissen.
    Daher hoffe ich das einer von euch bescheid weiß.
  5. oisingrehan Cupcake Jan 13, 2019
