battery
  1. A1541181062298
    Eclair Feb 23, 2020
    A1541181062298 , Feb 23, 2020 :
    day by day battery draining getting worst after 10.3.1battery draining fast without using even in battery saver mode also
  2. Kytharsis
    Nougat Feb 23, 2020
    Kytharsis , Feb 23, 2020 :
    Um. You gonna show us any screenshots or expect us to mind-read? ;)
    Caomhin and GeekOnTheHill like this.
  3. A1541181062298
    Eclair Feb 23, 2020
    wat screen shot u need
  4. Kytharsis
    Nougat Feb 23, 2020
    Battery graphs and detailed usage. Show us the apps you're using.
    Caomhin likes this.
  5. A1541181062298
    Eclair Feb 23, 2020
    after charging my mobile to 100 percent kept my mobile in battery saver mode after 12 hours my charge is 12 percent only
  6. A1541181062298
    Eclair Feb 23, 2020
  7. Kytharsis
    Nougat Feb 23, 2020
  8. A1541181062298
    Eclair Feb 23, 2020
  9. Kytharsis
    Nougat Feb 23, 2020
    I'd get rid of that... (squirrel app I can't think of the name of) for one.
  10. A1541181062298
    Eclair Feb 23, 2020
    wat is the solution for this
  11. Caomhin
    KitKat Feb 23, 2020
    Caomhin , via OnePlus 6T , Feb 23, 2020 :
    As per @Sufwan, Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    Also just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    A1541181062298 likes this.
