Battery via OnePlus 6T
  1. E1565941745438
    Cupcake Sep 22, 2020
  2. zayn_ys
    Ice Cream Sandwich Sep 22, 2020
    zayn_ys , Sep 22, 2020 :
    For battery draining and heating issue try this.
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Thanks to @Caomhin
