battery
  1. G_Ahmed_Mohamed_wduZ
    Cupcake Mar 26, 2017
  2. G_Ridwan_Saleheen_jqns
  3. Brooklyn701
    Honeycomb Mar 26, 2017
    Brooklyn701 , Mar 26, 2017 :
    Yes please enlighten us how you do that and what your configuration is. I have about 7 hrs and I've never reached 10.
    #43
  4. Kiran.a.joseph
    Jelly Bean Mar 26, 2017
    Kiran.a.joseph , Mar 26, 2017 :
    I turn ON the sensors like wifi, Bluetooth, location and nfc only when I want to use it. Otherwise I keep it off.
    Turned on Aggressive doze mode
    Turned on App auto-launch
    Disable auto back up
    Turned off notifications of news apps like bbc, times now, manorama etc
    Many apps like bbc, firefox sends usage stats by default. I have turned it off in these apps.
    Turned off wifi and Bluetooth scanning
    I dont play games in mobile
    I use it for calls in whatsapp/skype (mostly in wifi), fb app, android pay, emails, camera and browse news apps
    Apps like cam scanner, youtube, banking apps, Instagram are not used very often, but used once in a while.
    #44
  5. Kiran.a.joseph
    SOT is just a reflection of the usage pattern. Its not the absolute measure of battery performance. If you have all your apps installed and your phone lasts for a days with around 5 to 6 hours of SOT, then I think its a good battery stat.
    I have posted my usage in the previous post.
    #45
  6. Kiran.a.joseph
    Also, I have not rooted my phone and I use stock launcher. I have used RR 5.8.2 in note 4 and I think it has far more customization than OOS and I think its more optimized, but I cant use android pay if I root OP3T. So I havent rooted OP3T yet.
    #46
  7. F_Mukul_Verma_VJCt
    Gingerbread Mar 26, 2017
    F_Mukul_Verma_VJCt , Mar 26, 2017 :
    Thanks mate,
    This I knew. I was asking for why the total of all percentages is not making up as 100%
    #47
    jfleeman1 likes this.
  8. shrey.khurana
    Froyo Mar 26, 2017
    #48
  9. Ankitasaha87
    #49
  10. Deactivated User
    Mar 26, 2017
    #50
    shrey.khurana likes this.
  11. jfleeman1
    Froyo Mar 27, 2017
    jfleeman1 , Mar 27, 2017 :
    Given the percentages method Android uses to display battery use, it will only add up to 100% when the battery is fully discharged. So, the percentage for a given app/process is not based on 100. This is due to the system's taking a percentage of a percentage.
    #51
    F_Mukul_Verma_VJCt likes this.
  12. anishgablu
    Cupcake Jun 23, 2017
    anishgablu , Jun 23, 2017 :
    the battery indicator symbol doesn't work properly once it's style changed to the circle one. While charging, it goes back to the default one!!
    Is it just me or is there someone else facing the same problem?
    #52
  13. The_Rock90
    Jelly Bean Jun 23, 2017
    The_Rock90 , Jun 23, 2017 :
    lol
    #53
  14. G_Gautham_Prasad_qyBO
    Donut Jun 23, 2017
    G_Gautham_Prasad_qyBO , Jun 23, 2017 :
    I used to get a days battery backup (24hrs) untill I updated my OnePlus 3 with the latest system update. Now battery backup is reduced by 50% with same amount of usage. this is really bad. Hoping for a fix on this soon.
    #54
  15. G_Ketan_Padhiar_aazM
    #55
