2
Battery/Charging Battery
  1. airiartev
    Jelly Bean Jan 18, 2017
    airiartev , Jan 18, 2017 :
    I bought Accubattery but im very frustrated.... I dont like the app... gsam battery was more clear
    #61
  2. G_Calvin_P._WHWZ
    Cupcake Jan 19, 2017
  3. hansinielsen
    #63
  4. LukeFro
    Cupcake Jan 22, 2017
    #64
  5. Walthy
    Gingerbread Jan 22, 2017
    Walthy , Jan 22, 2017 :
    nope... but i did uninstall the fb + messenger app and installed fb lite instead. :)
    #65
  6. Anil S kumar
    Cupcake Jan 28, 2017
    #66
  7. TudorEmanuel
    Cupcake Jan 30, 2017
    TudorEmanuel , Jan 30, 2017 :
    How are you getting such great times, I've the same version of OOS and i get only 5h SOT. What are your settings..
    #67
  8. Deactivated User
    Jan 30, 2017
    #68
  9. G_Sid_Gog_gucx
    Honeycomb Jan 30, 2017
    G_Sid_Gog_gucx , Jan 30, 2017 :
    So the thing here is it's your perception of battery life which is wrong here. If there's heating issue and really fast battery drain then backup everything on your phone and do full reset. If issue still persist then revert back to previous version. Don't flash Ota because that's a patch. Download full ROM from website and flash.
    #69
  10. kiran262529
    #70
  11. SBAJANIYA
    #71
  12. G_Shravan_Kumar_Singamse
    Donut Jan 31, 2017
    G_Shravan_Kumar_Singamse , Jan 31, 2017 :
    I was facing differenrt problem with dialler and battety. my battery was draining v very fast. almost the total battery sucks in 6-7 hrs. when call is received and after completing the same the screen becomes blank for a while and comes back to home screen. please fix these bugs.
    #72
  13. sasi_kumar.s
    Cupcake Jan 31, 2017
    #73
    soniacastro likes this.
  14. G_Freddy_Quintero_Kelly_
    Eclair Jan 31, 2017
    G_Freddy_Quintero_Kelly_ , Jan 31, 2017 :
    Hi guys! I'm having some issues with the battery, it's draining so fast. I have very little knowledge about this cellphone stuff but I am sure you guys could help me out.
    Before this past weekend I was getting around 4 1/2 to 5 hrs of SOT, and being honest with you, I thought that was okay and was working out perfect for me. Now that I came back from vacations (I took lots of pictures, videos, Google Maps, Android Pay, YouTube, etc) I usually keep the screen brightness around 30-40%.
    I rebooted my phone to see if that was the problem and I actually lost 1 percentage after doing that.
    What can I do? this never happened before. I'm running OOS 3.5.4 Android 6.0.1
    #74
  15. [GG]
    Jelly Bean Jan 31, 2017
    [GG] , Jan 31, 2017 :
    Is battery too low on android 7?
    Everyone knows you have to open up the back of the phone and lower the battery to be able to fit Nougat in there.
    #75
  16. soniacastro
    Cupcake Feb 13, 2017
    soniacastro , Feb 13, 2017 :
    Hi people.
    Have a op3, updated the oxygen 2 days agk. Since then, My battery has run out very very fast!
    Yesterday, with baterry at 100%, went to bed and 9h later, when i was about to check which time it was, My Phone turned down with 0% of battery, WITHOUT ANY USE!
    Recharged it, and after 3h with minimum use, is already at 16%!
    Didn't wiped the cache, should i try it? Doesn't have Facebook installed, Just the messenger.
    Thanks
    #76
  17. AbieAmadea
    #77
  18. soniacastro
    Cupcake Feb 14, 2017
    soniacastro , Feb 14, 2017 :
    Wiped the cache, all good now. Battery life restored. And also, it was getting really Hot on the back, not anymore
    #78
  19. nickpsil
    Honeycomb Feb 20, 2017
    #79
  20. Joshua thummalacharla
    Cupcake Feb 20, 2017
