15
Battery
  1. Jgon9
    Donut Apr 22, 2017
    Jgon9 , Apr 22, 2017 :
    Glad to see I'm not the only seeing big battery drainage inexplicably after the last update...
    #41
  2. G_Harsh_Kothari_ocwV
    Froyo Apr 22, 2017
    G_Harsh_Kothari_ocwV , Apr 22, 2017 :
    Best way is to put on battery saver for a couple of days. Charge it to only 90 and drain to 40. Start cleaning cache everyday with a good app and turn off wifi when not needed.
    #42
    barpit90 likes this.
  3. Ashwinmhatwalne
    Eclair Apr 22, 2017
    #43
    F_Suresh_Bangla_pauz likes this.
  4. shahnisarg14
    Froyo Apr 22, 2017
    shahnisarg14 , Apr 22, 2017 :
    Im system apps disable google app and then agaim unable it, then go to play store and update it! Also clear all data from location service!
    I used to have same issue but after doing this, battery issue went away!
    #44
  5. crazyguy59
    Donut Apr 22, 2017
    crazyguy59 , Apr 22, 2017 :
    The main issue here is after updating to android 7.1.1, its getting over heated and the battery is getting down fastly when observed before upgrading.
    #45
  6. jim262
    Ice Cream Sandwich Apr 22, 2017
    jim262 , Apr 22, 2017 :
    There is no battery issue. If you wiped everything and allowed it to sit overnight and it still lost that much, would it then be a battery problem. But the reality is you have an OS and data loaded on your device. If it was caused by the OS that was the problem, everyone running the OS would also have similar problems. Since that isn't the case, that only leaves one other option, data. More than likely, third party data/app is the culprit of your issues.
    #46
  7. Jitendra678
    Froyo Apr 22, 2017
    #47
  8. Kamalakar_Seela
    Cupcake Apr 22, 2017
    Kamalakar_Seela , Apr 22, 2017 :
    same dude in beginning my battery backup used to come for 1 and half day and now it is drianing with hald day any leads on this please help
    #48
  9. ArpitBansal96
    Froyo Apr 22, 2017
    ArpitBansal96 , Apr 22, 2017 :
    sure, I'll try that
    #49
  10. ArpitBansal96
    Froyo Apr 22, 2017
    sir in my phone, issue was caused by google app
    #50
  11. nwz2001
    Donut Apr 22, 2017
    nwz2001 , Apr 22, 2017 :
    Im dacing this issue since 4.1.3 update. Its happening everyday when im at wirk (phone stay in pocket that time) ph getting extremely hot and it goes from 100% to 30% within 1 or 2 hr.
    I never face this issue on earlier version.
    #51
    Blueluz likes this.
  12. digin777
    digin777 , Apr 22, 2017 :
    my one plus 3t is also having battery issues before the lates update of 7.1.1 it was very good nw its really baad
    #52
  13. ghostofcain
    Marshmallow Apr 22, 2017
    ghostofcain , Apr 22, 2017 :
    v v v v v
    Indeed
    #53
    Sun90 likes this.
  14. Yash Bhardwaj
    Jelly Bean Apr 22, 2017
  15. G_Richard_Webb_REdP
    G_Richard_Webb_REdP , Apr 22, 2017 :
    mine was doing the same, getting warm and killing the battery very quickly, down to a full battery lasting less than a working day. i have this morning cleared the cache via recovery mode (not a full factory reset) and it hasn't yet got warm and after a full day of using the phone it's still at 45% , so this seems to have worked for me at least.
    if you've not done the cache delete I'd suggest try that first, as it doesn't lose any data or anything else that matters.
    #55
  16. Cari Litos
    Cari Litos , Apr 22, 2017 :
    i have the same problem
    #56
  17. jim262
    Ice Cream Sandwich Apr 23, 2017
    jim262 , Apr 23, 2017 :
    That is a third party app that is included with the OS, but not developed by OnePlus.
    #57
  18. F_Nikhita_Begani_irPK
    Donut Apr 23, 2017
    #58
  19. Ravi622teja
    Cupcake Apr 23, 2017
    #59
  20. Beniproff
    #60
