battery
  1. L1518075756848
    Cupcake Feb 8, 2018
    L1518075756848 , Feb 8, 2018 :
    battery of my one plus 5T has started draining very fast. It was fine a week before but since one week I am facing a lot of issues with my device
    please help
    Md_Ahad_Hawlader likes this.
  2. stark2991_PL
    KitKat Feb 8, 2018
    stark2991_PL , Feb 8, 2018 :
    Reboot your phone and check
  3. L1518075756848
    Cupcake Feb 8, 2018
  4. G_Angelos_Theo_(angelos)
    Honeycomb Feb 8, 2018
    G_Angelos_Theo_(angelos) , Feb 8, 2018 :
    Check which apps you installed this last week or which apps got an update. This may be hard when you have multiple applications installed but I faced the same issue with previous phones. So I uninstalled as much as I could (less important stuff) and it turned out that it was the 3rd party launcher's fault. At the next update it was totally fixed.
  5. vivekgokulraj
  6. G_Angelos_Theo_(angelos)
  7. R1528382019603
    Cupcake Sep 4, 2018
    R1528382019603 , Sep 4, 2018 :
    Hi,
    Am facing issue on battery from last two days wen I checked for t battery status it is showing as t Android system is consuming more battery I forced stop tat then too it was running and consuming more battery please provide some solution to it...
  8. haimgreenberg
    Honeycomb Sep 4, 2018
  9. vivekgokulraj
    Honeycomb Sep 5, 2018
    vivekgokulraj , Sep 5, 2018 :
    reboot into recovery and clear system cache.
