2
beep sound for no reason !!!
  1. sharathchelsea
    Gingerbread Apr 22, 2018
    D1524151712305 and AbidAbdullah like this.
  2. AbidAbdullah
  3. sharathchelsea
    sharathchelsea , Apr 22, 2018 :
    do you know what's the reason ??? I get it every now and then are you using 3T ?
  4. G_JUNAID_GANDHI_qVIx
    Eclair Apr 22, 2018
    G_JUNAID_GANDHI_qVIx , Apr 22, 2018 :
    I had same problem.
    It may be because of 'Evernote' app. So I delete it. Now problem is solved.
    If you have Evernote app in your OP 3T then delete it.
  5. sharathchelsea
    Gingerbread Apr 23, 2018
    sharathchelsea , Apr 23, 2018 :
    I don't
  6. Hydra Bob
    Starting Point Expert Apr 23, 2018
  7. D1524151712305
    Cupcake Apr 23, 2018
  8. Luis Estanislao
    Cupcake Sep 18, 2019
    Luis Estanislao , Sep 18, 2019 :
    Pls, anyone has discovered the reason and solution for this issue?. I have it in 2 different OP3T!
    Pls help!
  9. ghostofcain
    Marshmallow Sep 18, 2019
    ghostofcain , Sep 18, 2019 :
    And does it still occur in safe mode?
