Beep Sound
  1. P1520925454504
    Cupcake Sep 3, 2018
    P1520925454504 , Sep 3, 2018 :
    Hey I am using one plus 5 from last week some kind of beep sound come from phone in every 5min .
    What's is that and how can I can solve this?
    Please help me..
  2. the_o2
    OnePlus 9 Series Expert Community Expert Sep 3, 2018
    the_o2 , Sep 3, 2018 :
    Boot to safe mode and check whether beep sounds is coming there or not, if not than its means any app is causing the problem, find that app and uninstall it.
    If beep sounds is still there in safe mode than maybe hardware issue, visit the service center or call the OnePlus support...
  3. GopalB.
    Nougat Sep 3, 2018
    GopalB. , Sep 3, 2018 :
    Sometimes its there due to NFC...
    Check if NFC is on...
  4. P1520925454504
    Cupcake Sep 3, 2018
  5. G_Mario_Fitzpatrick_XUNZ
    Honeycomb Sep 3, 2018
    G_Mario_Fitzpatrick_XUNZ , Sep 3, 2018 :
    Maybe someone is tracking you based on the porn you watched earlier and beeping indicates stable connection was established. I mean who knows..who knows..
  6. P1520925454504
    Cupcake Sep 24, 2018
    P1520925454504 , Sep 24, 2018 :
    how do I stop this.
    What are step should be able to do to stop that beep sound...
  7. frankkn85
    Eclair Sep 24, 2018
    frankkn85 , Sep 24, 2018 :
    that comes from some site which loads cookies it makes beep from phone or keeps your phone to vibrate...to rectify just clear your cache memory but before kill all the history from chrome and exit
    Gawtaman likes this.
  8. S1537468117884
    Cupcake Sep 28, 2018
    S1537468117884 , Sep 28, 2018 :
    just follow these steps
    1. power off
    2. long press of volume down button + power button
    together
    3. enter your phone password
    4. select wipe cache and data to clear cache
    5. reboot phone.
    issue gets solved
    if still exists then repeat above steps again.. you won't get beep sound again.
  9. Aakruti Ruia
    Donut Sep 28, 2018
    Aakruti Ruia , Sep 28, 2018 :
    I had same issue....go to your sim toolkit and turn flash notification off. try it might work
  10. S1537468117884
  11. Gawtaman
    Cupcake Nov 28, 2018
    Gawtaman , Nov 28, 2018 :
    if i select wipe cache and data, will my phone datas will be completely erased???
