489
Behind the scenes: How we adapted to Android Pie
  1. Ramesh Subudhi Donut Oct 9, 2018
  2. Ramesh Subudhi Donut Oct 9, 2018
  3. chriskoups Froyo Oct 10, 2018
    chriskoups, Oct 10, 2018 :
    can you add a brightness controller for auto?
    Samsung for example has a range ±2 for the auto.... or even better have the opportunity to have a custom line.
    more or less what Lux (the app) is doing but more efficiently!
    using sub-zero brightness help for eye strain and battery levels as the OLED displays can be turned off.
  4. J1513478345908 Eclair Oct 11, 2018
    J1513478345908, Oct 11, 2018 :
    Well in all honesty Google debuted Android Pie for pixel 2 and when the release their flagship device Android P was pre installed. Why is it when Android P came out the one plus 5 nor 5t got the update first instead it's the current flagship. Maybe it's time to move forward and know how to appreciate your customers. Well it's my 2 cents. don't have to be harsh or be an arsehole for the comment above..
    Santoshtheone likes this.
  5. RazzSekhar Cupcake Oct 11, 2018
    RazzSekhar, Oct 11, 2018 :
    It seems there is a problem with Android P update in my Oneplus 6. While dismissing a notification of an music app in the task bar, I swiped the notification right and holded on for few seconds, it prompted me "Keep showing" and "Minimize". Accidentally, I selected "Minimize" and didn't "Undo" it. After this, I am not getting the notification in lock screen even though I am playing music from that app. I tried enabling all options in "Notifications" of that particular app, but still I am facing the same problem.
  6. gopaljha29 Cupcake Oct 12, 2018
  7. eno_cepa Donut Oct 12, 2018
    eno_cepa, Oct 12, 2018 :
    Everything looks cool, accept widget page. I'll think they looked way cooler in oreo. Here the name of the widget is taking to much space.
  8. udaykanth mekala Cupcake Oct 12, 2018
  9. G1534519579444 Cupcake Oct 13, 2018
    G1534519579444, Oct 13, 2018 :
    This app is not working with Fitbit Charge -2,so Fitbit is not syconising in Mobile app after updating above Android 9 pie ,so kindly instruct how it will work syconising
  10. Ramesh Subudhi Donut Oct 19, 2018
  11. L1535879402668 Gingerbread Oct 21, 2018
    L1535879402668, Oct 21, 2018 :
    The update that halved my battery life. sent my phone from being fantastic to being a failure. give me more battery power over speed and gimmicks any day. please fix the battery right away. this update was a failure. I left apple for this same reason. I came to one plus for the impressive battery performance. and now it's rubbish. so disappointed.
  12. L1535879402668 Gingerbread Oct 21, 2018
    don't update. it halves your battery life. I mean it.
  13. L1535879402668 Gingerbread Oct 21, 2018
  14. L1535879402668 Gingerbread Oct 21, 2018
    agreed. awful. they've wrecked the phone with one update.
  15. L1535879402668 Gingerbread Oct 21, 2018
    do not update. worst update I will ever had on any phone. never again will I trust a one us update. it's destroyed my phone.
  16. L1535879402668 Gingerbread Oct 21, 2018
    same. mine is probably worse. phone went from lasting 30 hours on my normal use to 8 hours.
  17. L1535879402668 Gingerbread Oct 21, 2018
    agreed. I don't think it's a scam but they've destroyed my phone.
  18. MaxsoundCarAudio Gingerbread Oct 22, 2018
    MaxsoundCarAudio, Oct 22, 2018 :
    Android P is far from ok yet as i personally are experiencing issues like yesterday the phone switched itself off and then when restarted all my contacts had gone? Also brightness issues, the loud speaker doesn't seem as good anymore and still there no separate volume control for eh text,WhatsApp,Viber message alerts like Samsung have had for years on all there phones. At the moment I prefer android Oreo over Pie and wish I could revert back [e]1f621[/e]
    L1535879402668 likes this.
  19. L1535879402668 Gingerbread Oct 23, 2018
    L1535879402668, Oct 23, 2018 :
    you can go back. I did. don't ask for advice here. it's not the best place for it. go directly to their site, phone them and get them to downgrade your system update. it's straightforward for them to do.
    MaxsoundCarAudio likes this.
  20. MaxsoundCarAudio Gingerbread Oct 23, 2018
