Hi All,
I would like to let you all know one of the
Major Bug that has been creeping unseen by most in all the Nightly of CM12 and ROMs that are built with CM12 base.
If you are a
Bluetooth device user and an
Audiophile then you need to read below very CAREFULLY!.
I have been keeping tabs on this issue from the beginning CM12's ALPHA builds and UNOFFICIAL's started rolling out.
Description of the issue:
When you connect your Bluetooth device (Stereo ones in my case) and play an audio (mp3 song for example) it all seems to be fine at first but it does
NOT!!.
BUG Xposed:
When you try increasing the volume from low to high or vice-versa the audio starts to increase seemlessly without control causing freaking
disturbances and sound cracks all through the audio. This is very much gonna affect both your headset and your ears
NO DOUBT!.
PLEASE share your feedbacks and thoughts or if you have any idea on HOW TO FIX THIS
FYI:
If you are the ONE with a Bluetooth audio device and an audiophile (like me) at the same time I sincerely suggest you to
stay in KK as long as the bug is fixed by CM team.
Greatly disappointed to know the bug is still there and CM has not done anything regarding it. Gonna see if a JIRA req has been raised for this issue and
downgrading to CM11s back again.
EDIT: DAMN! FORGOT JIRA Repository ain't set for LOLLIPOP yet.Bummer!
EDIT 2: TRIED on 01182015 Build and still it ain't fixed
ANY1 on Today's 01202015 build try and pls update.
EDIT3
27/01/2015)
Tested on 20150127 NIGHTLY Build still got it.
This BUG is listed as a
REGRESSION ONE so CM Team is aware of it..I even read somewhere that it was a bug in 5.0.0 which was later fixed in .01 and .02 but somehw the commit was missed in CM code.
Sources:
https://forums.oneplus.net/threads/bluetooth-audio-bug-cm12-nightly.239350/
http://forum.cyanogenmod.org/topic/103486-cm-12-official-nightlies-problems/
http://forum.xda-developers.com/showpost.php?p=57791861&postcount=3446Click to expand...
