Bepak Tempered Glass issue
  1. sandeeppathak007
    Ice Cream Sandwich Dec 22, 2014
    sandeeppathak007 , Dec 22, 2014 :
    Hi All,
    I received my Bepak Tempered glass screen protector and the installation went well, however I am seeing a rainbow patch/effect at the bottom left side of the screen , please share your views/opinion as what shall I do.
  2. meatandy
    Oreo Dec 22, 2014
    meatandy , Dec 22, 2014 :
    Pull it up at the bottom and recenter it.
    If its to close to the edge of the screen.
    Mine was the same ,its fine now.
  3. Lunatasian
    KitKat Dec 22, 2014
    Lunatasian , Dec 22, 2014 :
    It seems like it may have been bent during installation or shipment. See if you can squeeze it out. If not, gently remove it and try to remove any dust with a sticker and reapply that portion of it.
    If nothing works, send it back. It came with a warranty, didn't it?
  4. sandeeppathak007
    It seems like glued like anything , how do i pull it up and redo it ?
  5. meatandy
    Oreo Dec 22, 2014
    What case is that on your phone?
  6. meatandy
    Oreo Dec 22, 2014
    Carefully slide a razor between the two.
    Insert Only enough to lift it up.
  7. Ismael Bakshi
    Honeycomb Dec 22, 2014
    Ismael Bakshi , Dec 22, 2014 :
    Noob :p
  8. sandeeppathak007
  9. sandeeppathak007
    Done, now looking Ok , but in process because I had already thrown away the installation packet in Dustbin I got few Lints in between screen and Protector , But i think I can live with that
    Lunatasian likes this.
  10. simonc76
    Jelly Bean Dec 22, 2014
  11. sandeeppathak007
    meatandy likes this.
  12. sandeeppathak007
  13. SaurabhArora
    Eclair Jan 18, 2015
  14. Subrata Roy
    Donut Apr 20, 2015
    Subrata Roy , Apr 20, 2015 :
    I ordered one bepak from **********...any one ordered from ********** before?? any idea how long it should take to reach delhi....seems the order can not be tracked
