5
Bepak tempered glass protector: change in cutout design
  1. psychoshrink
    Froyo Dec 3, 2014
    psychoshrink , Dec 3, 2014 :
    Hey.. The screen protector IS legit. It's definitely glass from what I can tell. Applies flawlessly, no hassles (provided you follow steps.) Being slightly klutzy I screwed my application up a bit.. but that was my fault.
    But as of now I'd say go with the OPO original accessory (whatever original means) Tempered Glass screen protector available on amazon india for 399. It's the cheapest and I'm sure well worth its price. I only say that because I don't feel the 300 rs more on other temp. glass stuff is justified.
    As of now all is well with the Bepak that's on my screen.
    talktome322 likes this.
  2. stormchip
    Gingerbread Dec 4, 2014
    stormchip , Dec 4, 2014 :
    HOKO is a plastic screen protector. It may prevent scratches but will not protect your One if you drop it. That's why most folks are going with tempered glass protectors. Yes, they cost a bit more but it beats having to pay a bomb to replace a broken phone screen.
    LipstickDragon and talktome322 like this.
  3. keith.n
    Donut Jan 10, 2015
    keith.n , Jan 10, 2015 :
    @ OP: Does the new version of the bepak retain the 2.5D rounded edges or not?
  4. Grubert
    Froyo Jan 10, 2015
    Grubert , Jan 10, 2015 :
    Yes, it does. Or at least it did in October. I don't know if there have been any other product changes later.
    keith.n likes this.
  5. keith.n
    Donut Jan 15, 2015
    keith.n , Jan 15, 2015 :
    Grubert I just received my Bepak screen protector.It doesnt feel anything like glass.Rather like a thicker plasticy film.Also I can see scratches on either side.So I am not sure if they are on the film that protects the glue side or on the touch side of the protector.
    Update:I am convinced its not original.The film does not even line up with the phone.I line up the top cut outs the bottom shifts.The cutouts seem to be offset so the film doesn't align.
    The protector does not even line up with the phone screen.Definitely a fake.
    The shocking bit is that the code comes up as authentic on the bepak website.Looks like they have figured out how to generate the code(keygen like the ones used on software)
    Purchased on Amazon.in
    Seller:Shopdrive
  6. gautamal
    Honeycomb Jan 15, 2015
    gautamal , Jan 15, 2015 :
    +1 for bepak temepered glass. It has a longer cutout, but its quite good. No loss of sensitivity and has a premium feel to it.I would recommend the same.
  7. alqasimk
    Eclair Jan 15, 2015
    alqasimk , Jan 15, 2015 :
    I ordered a no brand name protector from ebay and it is just perfect. smooth, round edges and open only to the speaker area
  8. Grubert
    Froyo Jan 15, 2015
  9. keith.n
    Donut Jan 15, 2015
    Yes have initiated the refund a second time around.Can you tell me how is a tempered glass screen protector different from a thick plastic one?The product I received seemed more plastic than glass.Frankly all plastic thicker ofcourse.How can we correctly identify the tempered glass product.This fake sub par one checked out as authentic on the Bepak website.
  10. Grubert
    Froyo Jan 16, 2015
    Grubert , Jan 16, 2015 :
    Try to scratch it with your keys. If it does scratch, then it's plastic.
    Note that a thin sheet of glass can be flexible but that doesn't mean it's plastic.
    Maybe it's not that it's fake, only defective.
  11. keith.n
    Donut Jan 16, 2015
    keith.n , Jan 16, 2015 :
    It came pre scratched.The touch felt like plastic is what I meant.Does tempered glass feel like plastic?
  12. J.Pinkman
    Jelly Bean Jan 16, 2015
    J.Pinkman , Jan 16, 2015 :
    A friend of mine also bought this one, but it a single camera cutout and proximity cutout, next to eachother.
  13. swamikapadia
    Cupcake Jan 16, 2015
    swamikapadia , Jan 16, 2015 :
    today i got my bepak screen protector from ebay.
    true its cut outs are longer.
    'll post it review later
  14. api182
    Ice Cream Sandwich Jan 16, 2015
    api182 , Jan 16, 2015 :
    I have an Ultimate Shield tempered glass protector on my OPO which literally only has the cut out for the earpiece grille. The proximity and ambient light sensors still work absolutely fine as does the front facing camera!
    I don't understand why they do that huge ugly cut out on others, seems unnecessary...
  15. leemartin
    Lollipop Jan 16, 2015
  16. althafrahsan
    Froyo Jan 17, 2015
    althafrahsan , Jan 17, 2015 :
    today i just recieved the bepak TG. I suspect its fake .I got the securty code from cover by scrching and checked on their website . I translated the page and GOT this
    Query Results / Search result
    BEPAK digital security system
    Query Digital: 4323108555281644
    Digital has your query query at 14:29 on January 17, 2015 over the digital has expired, to guard against counterfeiting, and please call the hotline 021-38625099. Thank you for using"
  17. keith.n
    Donut Jan 17, 2015
    keith.n , Jan 17, 2015 :
    Yes that would mean this code has been used by someone else before.
  18. althafrahsan
    Froyo Jan 17, 2015
    do you still have your code with you? or noted it ? anybody has this experience before?
    #38
  19. keith.n
    Donut Jan 17, 2015
    Mine came as original.Even though it didn't fit the phone.
    Where did you order it from?How does it feel?
    #39
  20. althafrahsan
    Froyo Jan 17, 2015
    @keith.n I bought it from ebay from THE SELLER allphoneunlock . I still didn't applied it. There is much visibil gaps when it aligned two sides correctly, and the other 2 sides have clear gaps. also there are too many finger prints . I draw a line with compass , and its does not get any scratches.
    #40
