Best alternate for OP2
  1. ravismiles4u
    Ice Cream Sandwich Sep 11, 2015
    ravismiles4u , Sep 11, 2015 :
    Hi,
    Please let me the best alternative for OP2.
    I've few choices::
    OPPO R7 plus - 4100mah
    New nexus 2015
    And any more...
    Please let me know. My phone has broken, now I'm using a Nokia old model phone.
    Thanks
  2. Zeals
    Gingerbread Sep 11, 2015
    Zeals , Sep 11, 2015 :
    The Moto X Pure/Style, or Moto X Play if you're willing to sacrifice a bit of performance for more juice.
    The original OnePlus One isn't a bad phone as well as is the ASUS Zenfone 2. Also the LG G4 has come down in price. Although personally I would probably choose one of the Moto X's if you can't wait until see what the Nexus 2015 will be like.
  3. uprisen
    Cupcake Sep 11, 2015
    Zeals likes this.
  4. ravismiles4u
    Asus I used, it becomes too hot and I don't like the Asus apps.. Battery life is not good.
    LG G4 - battery is 3009mah, don't have dual sim
    Moto x - battery is even worse 2850mah
    I'm looking some phone with good battery, performance, dual sim, finger print etc
    Thanks for comments
  5. Zeals
    Moto X's are 3000 mAh and 3630 mAh hours depending on the model...Although they lack dual sims and finger print scanners, so I guess the Lenovo ZUK Z1?
  6. ravismiles4u
    This is the best alternative!! With 4100mah battery, cyanogenmod 12.1, 8mp front camera
    John j likes this.
  7. ravismiles4u
    You are true, ZUK Z1 has the all features OP2 and cheaper with 100$ difference
    sunilbagalur likes this.
  8. aaron.hossain75
    Lollipop Sep 11, 2015
    aaron.hossain75 , Sep 11, 2015 :
    Performance for the battery is optimized by the software and moto x has stock android so you can't tell the difference :)
  9. Zeals
    Near stock Android technically.
  10. evilone
    Jelly Bean Sep 11, 2015
    Gavin McAnally likes this.
  11. sunilbagalur
    KitKat Sep 11, 2015
    sunilbagalur , Sep 11, 2015 :
    Also check for the "Display Protection (Gorilla Glass/Dragon Glass) ...
    GPU is slightly lower generation ...
  12. aaron.hossain75
  13. Zeals
    Well realistically, quartz (sand) will scratch either material. And if you're going to be dropping your phone, majority of the time if it lands the wrong way, GG screen. The difference between Gorilla Glass and Dragon Glass is minimal if you ask me all things considered, you can argue one is slightly stronger or scratch resistant, but until someone makes a glass that is unscratchable and impact resistant to like a 2 metre drop onto concrete even when it lands screen first, I'll just say, if it's strengthened it's enough for me.
  14. ravismiles4u
    Can you pls let me know R7 performance, once it's in your hands!
  15. ravismiles4u
    You are true! We can use tampered glass protector for extra protection!!
  16. sunilbagalur
    KitKat Sep 11, 2015
    Yeah ...
    That is correct @Zeals ...
    I was asking @ravismiles4u to check that is okay for him ...
  17. ravismiles4u
    I'm OK to buy ZUK Z1 .. but I think it's not released in Singapore yet!
    Need to wait!
    Also I've in mind area nexus 2015 both 5&6 ... I'm little confused!
  18. ravismiles4u
  19. ravismiles4u
  20. baulee56
    baulee56 , Sep 11, 2015 :
    Yes.. new nexus will be a good aletrnative. If you want a better camera, than go for LG G4 (low light shots are amazing). About Oppo's R7.. I really like bezelless design
