best custom rom with gpay
  1. tomashen
    Gingerbread Oct 19, 2020
    tomashen , Oct 19, 2020 :
    Anyone can tell me what is the best custom ROM for better battery life , and i need GPay to pay with NFC! i need banking apps to work and paypal etc.
    OnePlus 7T .
    thanks
    Kerkdriel_Online likes this.
  2. Tokolozi
    Most Original Avatar Oct 19, 2020
    Tokolozi , Oct 19, 2020 :
    Since android implemented more strict security checks in android 10, your best bet would be an android 9 based one.
  3. tomashen
    but going to a older version would have drawbacks right? if not, which rom would be best
  4. #4
    Tokolozi and BeingIncog like this.
  5. oldusername
    Gingerbread Oct 20, 2020
    oldusername , via OnePlus 7T , Oct 20, 2020 :
    It's only Resurrection Remix. Thanks to messed up Google keystore implementation by One Plus Dev, you cannot have rooted Oxygen.
    Check RR telegram account for OP 7T. You can apply magisk safetynet to bypass security checks by banking apps.
  6. oldusername
    There is no Android 9 rom. 7T launched with 10. It will always have 10 and above
  7. inferno0230
    Froyo Oct 20, 2020
    inferno0230 , via OnePlus 7T , Oct 20, 2020 :
    Its possible to root oxygen OS its just a bit tricky as you have to Manually patch boot.img and flash it to active slot
    I have used OOS 10.3.4 and Beta 7 rooted and using beta 8 rooted too
