best earphones for 6t.?? any one suggest .? and also suggest for conjunction with charging and mic
  1. Lohit basa Cupcake Jul 14, 2019
    G_abhijeet_swain likes this.
  2. G_abhijeet_swain Donut Jul 14, 2019
    G_abhijeet_swain, Jul 14, 2019 :
    oneplus has its own bullet's series check them out.. Else go for onemore sigle driver, but the best is oneplus bullet's .
    I am using oneplus bullet's type-c with op6 it's AmaZing.
    Muhsin_Sultan likes this.
  3. YRJ Lollipop Jul 14, 2019
    YRJ, Jul 14, 2019 :
    Bullets type C sound good.
    If you wish, you can try RHA also, they are great! They have both wired and wireless options.
    Kytharsis and G_abhijeet_swain like this.
  4. JP Llaga Froyo Jul 14, 2019
    JP Llaga, Jul 14, 2019 :
    I'm using an AKG earphone for my OnePlus 6T and it sounds goood also... but I want to try the quality of the OnePlus Type-C earphones just in touch.. also, tip: any dongles (type-c) will work for OnePlus 6T and 7, 7 Pro...but I recommend the OGs when available. :)
