3
Best Google Cardboard for OPO
Do you like the Google Cardboard?
This poll will close on Dec 30, 2020 at 4:00 PM.
  1. I love it! Amazing idea!
    70.8%
  2. OK idea, but could be better
    14.4%
  3. What in the...I say what in the hell is a Google Cardboard?
    14.7%
  1. DanCtoo
    Honeycomb Mar 26, 2015
    DanCtoo , Mar 26, 2015 :
    Think so, there is a round piece of foam inside the lid to press the phone against the goggles (has foam edge) you may have to cut off a littlebit of this round piece.
    #81
  2. DanCtoo
    Honeycomb Mar 30, 2015
    DanCtoo , Mar 30, 2015 :
    I was looking for a vidplayer that can handle custom aspect ratios.
    You will need this because most side-by-side vids out there are compressed (or horizontally squashed if you like) For example, most youtube SBS HD movies have the two screens in a 1920x1080 (16:9) format.
    When you play this vid everything is squashed horizontally offcourse.
    Aspect ratio has to be set to 32:9 in order to show correctly (two 16:9 screens side-by-side).
    VLC on PC for instance can be set to this aspect ratio but not in android version.
    BS player, MX player etc...forget it.
    One player i found where you can set ANY custom aspect ratio is Moboplayer.
    https://play.google.com/store/apps/details?id=com.clov4r.moboplayer.android.nil
    Downside is that you can't save the custom aspect ratio, you have to set it everytime you start the player.
    #82
  3. inqbus406
    Gingerbread Apr 9, 2015
    inqbus406 , Apr 9, 2015 :
    I'm gonna disregard what you say since you can't seem to spell.
    #83
  4. TekRantGaming
    Ice Cream Sandwich May 30, 2015
    TekRantGaming , May 30, 2015 :
    there's lots of different ones
    #84
  5. sandeepkonda
    Donut May 30, 2015
    #85
  6. Rubii23
    Jelly Bean May 30, 2015
    Rubii23 , May 30, 2015 :
    Mine [​IMG]
    See link in signature [​IMG]
    #86
    azp3 likes this.
  7. bestmak
    Gingerbread Aug 6, 2015
    #87
  8. mark9389
    Cupcake Aug 6, 2015
    mark9389 , Aug 6, 2015 :
    I received my One Plus Cardboard a couple of week before the OP2 launch and after trying several apps i was very impressed with the experience but found the Cardboard uncomfortable and the design of the select switch did not work on most of the games/apps . I ended up buying the Homido Headset with a small Bluetooth controller . This headset in comfortable and comes with much more adjustment for depth of field and eye spacing . In short the Google Cardboards are good but if you like the experience you will buy a more expensive headset
    #88
  9. DustinDep
    Ice Cream Sandwich Aug 6, 2015
    #89
  10. DustinDep
    DustinDep , Aug 6, 2015 :
    I also have headset that I use off of amazon that I prefer as you can adjust the lens to make it perfect, a bt controller is a must though!
    #90
