Best OP2 ROMs
  1. Char7simons
    Gingerbread Apr 28, 2017
  2. jcagara08
  3. dpalejwala
    Honeycomb Apr 28, 2017
    dpalejwala , Apr 28, 2017 :
    Currently using cosmicOs.
    Has the best battery life among all Roms.
    Performance is also good. Nothing to complain about.
  4. rickvdsommen
    Ice Cream Sandwich Apr 28, 2017
    rickvdsommen , Apr 28, 2017 :
    Currently using Resurrection Remix OS
    It runs stable on my oneplus 2.
    This rom has the most customization options and runs like a beast!
    sumsulk and kvp@1+ like this.
  5. ShortyEx
    ShortyEx , Apr 28, 2017 :
    Will be clean flashing LineageOS again this weekend now that they've merged the OOS3.5.8 sources.
    In doing so they are one step ahead imho :)
  6. kvp@1+
    kvp@1+ , Apr 28, 2017 :
    I'm on the Resurrection Remix 5.8.3 build and it is awesome !
    If you want customization then RR is the best I've ever seen.
    It is stable, no major bugs and the battery life is amazing... :)
    I can't tell you if its the best but I get around 6 hrs of SOT and that's enough for me. ;)
  7. Flyologist
    Jelly Bean Apr 28, 2017
  8. sumsulk
    Gingerbread Apr 29, 2017
    sumsulk , Apr 29, 2017 :
    RR is the best for me, Unofficial SONI's build. DU is also great. Both go hand to hand in terms of performance and customization.
  9. cooldufff
    Eclair Apr 29, 2017
    cooldufff , Apr 29, 2017 :
    could you plz provide the link of RR 5.8.3
  10. AaronStark171
    Ice Cream Sandwich Apr 29, 2017
    AaronStark171 , Apr 29, 2017 :
    any network drops?
    are u using google contacts or hangouts?
    are there any random power offs?
    how much sot are we talking about.. and I understand it varies per user, but like as compared to stock or lineage os.
  11. kvp@1+
    Gingerbread Apr 30, 2017
  12. cooldufff
    Eclair Apr 30, 2017
  13. gaurav_kale
    Cupcake Apr 30, 2017
  14. kvp@1+
    kvp@1+ , Apr 30, 2017 :
    You're flashing old gapps !
    Download the gapps again and then flash.
    I had the same problem using new gapps solved it.
  15. Goku_SuperSaiyan
    Ice Cream Sandwich Apr 30, 2017
    Goku_SuperSaiyan , Apr 30, 2017 :
    volte works on resurrection remix ?
  16. F_Hashim_ELsir_KYSo
  17. rohit0807
    Eclair Apr 30, 2017
  18. jizang
    Lollipop Apr 30, 2017
    jizang , Apr 30, 2017 :
    are you from the future? there's no OOS 4.1.1 for OP2 currently
  19. rohit0807
    Eclair Apr 30, 2017
    rohit0807 , Apr 30, 2017 :
    I never said that I am on it. He asked for the best rom... There is no best rom also because dev works too hard not to complete with each other. All Roms are good..
  20. jizang
    yes ...asked for best ROM for OP2 ... so my quote still stands
