Best Rom+Kernel?
What is your favorite official ROM?
  1. CyanogenMod
    61.8%
  2. ColorOS
    12.7%
  3. MIUI
    7.8%
  4. SlimROM
    15.7%
  5. Paranoid Android
    16.7%
  6. Pac Man ROM
    6.9%
Multiple votes are allowed.
  1. SeksieJonas
    Honeycomb Jul 25, 2014
  2. oscarvanl
    Jelly Bean Jul 25, 2014
    oscarvanl , Jul 25, 2014 :
    Its not an issue for everyone, but lots of people have wakelocks from Google Play Services on their phone. You can see what is producing wakelocks with an app called wakelock detector. You can fix the wakelocks but it sometimes requires root access.
    The Google play services wakelock is being fixed in the next OTA update.
  3. SeksieJonas
    SeksieJonas , Jul 25, 2014 :
    Well, read much about this. But don't know how to solve :) Next OTA from CM11S or Stock? I'm currently using Paranoid Android :) + Have root ;)
  4. patstar5
    Jelly Bean Aug 6, 2014
    patstar5 , Aug 6, 2014 :
    Anyone been trying out all the roms? Which one has the best battery life? I have pacman rom right now because my vibrator wasn't working on CM 11s. Battery life was better 1st day, today it has been horrible. 2 1/2 hours on screen, that is with charging it to 90% after it was almost dead. Well screen shows 32 %, android system 18%, android os 12%. Will see how it goes tomorrow.....
  5. jshjx
    jshjx , Aug 6, 2014 :
    just curious, have u flashed any ROMs yet? ive heard of many that since flashing ROMs they are experiencing issues.
    venom773 likes this.
  6. RogueS4
    RogueS4 , Aug 6, 2014 :
    android system and os are way to high. Your probably being affected by wakelocks and need to check which programs are causing it.
  7. patstar5
    Anyone have download link for stock cm 11s rom? Going to try Pacman for a week and then switch back, I do have nandroid backup of it but then my vibrations wouldn't work again.
  8. patstar5
    Is there an app for this?
  9. patstar5
  10. thegdub
    CIB3R and The_Hoff87 like this.
  11. patstar5
    You have download link?
  12. RogueS4
  13. ezequielin2580
    Ice Cream Sandwich Aug 6, 2014
    ezequielin2580 , Aug 6, 2014 :
    If I was you, I would wait until Android L gets released. Android L will be more battery friendly, and some people are reporting problems with the custom ROMs. Also, there isn't that much of a difference between the ROMs.
  14. VootFr
    VootFr , Aug 6, 2014 :
    Stock ROM means the default ROM, the ROM which comes installed in your OPO so you don't need any download link considering it's already on your OPO
    The_Hoff87 likes this.
  15. The_Hoff87
    Honeycomb Aug 6, 2014
    The_Hoff87 , Aug 6, 2014 :
    Yup, I get days worth of usage with the stock ROM.
  16. Jonnyn93
    Jonnyn93 , Aug 6, 2014 :
    Its a hard decision really, stock rom would be the best generally, but some of the custom ones probably have more features. If the rumor about 1+1 and CM are true then we will likely see more custom roms soon.
    hopo16 and matthkang like this.
  17. Yanchen
    Yanchen , Aug 6, 2014 :
    I used SlimKat for a while, battery seemed about the same, but I switched back due to some apps not really working
  18. kufikugel
    SlimROM Aug 6, 2014
    kufikugel , Aug 6, 2014 :
    Like?
    #38
  19. Yanchen
    A lot of games crash even after multiple reinstalls. Sorry, I don't really remember which ones as I've restored back, but I know QuizUp in particular gave me tons of problems. It would let you finish a game but then would crash immediately after, which was really annoying. I'm not exactly sure what caused it. Also had some problems with not getting any notifications for a while, but that sorted itself out.
    Anyways, when the new weekly comes out, I'll be sure to go back, I like the ROM too much c:
    (Sorry for hijacking thread)
    #39
    kufikugel likes this.
  20. kufikugel
    SlimROM Aug 6, 2014
    Well first stable build was released last night :p
    On any rate be sure before you switch the system to format system partition and data and cache. The flash ROM and slim gapps.
    Till now we did not have any crash reports on games neither on weekly nor on stable. If you still experience it upload a bugreport please.
    #40
