Best tempered glass for OP9 PRO via OnePlus 9 Pro
  1. ady_agar
    Froyo Aug 1, 2021
    ady_agar , via OnePlus 9 Pro , Aug 1, 2021 :
    Hi guys.
    What's the best tempered screen protector for op9 pro in your experience? Also, please link the same or mention where it was purchased from.
    (It's hard to import from outside of India. I'm looking for options within India)
    Thanks
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 1, 2021
  3. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Aug 1, 2021
  4. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Aug 1, 2021
    OALEXANDER , Aug 1, 2021 :
    You can check on Amazon. I got one done locally from a shop and it's perfect fit.
    If you are buying online..check the videos how it's done since you are using Glue + UV to have it sticked.
    Dresa91 likes this.
