Best UK Alternative Charger
  1. Willza3
    Gingerbread Dec 16, 2014
    Willza3 , Dec 16, 2014 :
    Personally, I think the UK edition of the OnePlus charger is horrible, it's basically a european charger with a loose adapter strapped on, I'm pretty sure the adapter also reduces the voltage. I found a great alternative that in my opinion is better than the OnePlus charger, it's called the Belkin PowerUp.
    I let my OnePlus charge on the plugs behind my bed, the OnePlus charger sticks out so much it barley fits behind my bed, I measured and the charger is 11cm!
    It also looks really stupid :mad:
    The Belkin charger actually fits where it needs to be and doesn't need some stupid adapter. Talking technically, the Belkin charger is also a lot better. The OnePlus charger outputs 5V - 2.1 Amps while the Belkin charger outputs 5V - 2.4 Amps :D
    Overall, I'm pleased with this charger; I'm experiencing fast charging for the first time and I don't have to carry around a stupid adapter anymore :rolleyes::D
  2. feluda
    Lollipop Dec 16, 2014
    feluda , Dec 16, 2014 :
    Good review, hopefully this helps others.
  3. JordanL18
    Honeycomb Dec 16, 2014
    JordanL18 , Dec 16, 2014 :
    I tend to not change my charger amp since it could reduce the battery life span but saying that 0.3 upgrade for the benefits it is giving it is a good choice, good find :)
