Best way to improve battery life?
  1. ismet
    Ice Cream Sandwich Oct 26, 2014
    ismet , Oct 26, 2014 :
    delete facebook app, use browser instead
    delete facebook messenger, use browser instead
    delete games that run in the background, deal with it
    give ART a try
    flash CM11 and Franco.Kernel r28
    set maximum CPU Frequency to ~2Ghz (plenty)
    delete anything else that cause a ridiculous amount of wakelocks like facebook and so on
    If you are rooted install "Disable Service" and "App Quarantine" and disable all location based services with the first app, warning though: NOTHING will be able to locate your device then, GPS wont work, even not for the cm account dashboard i believe
    with the second app you disable apps you dont use, but cant uninstall
    done 5-6hours on screen time no problem, idle drain = 0,2%/hour / 8mA
  2. amorosa
    Honeycomb Oct 26, 2014
  3. Popular_Culture
    Gingerbread Oct 26, 2014
    Popular_Culture , Oct 26, 2014 :
    Greenify Facebook and Facebook Messenger (denying awake and keep awake also helps)
    Deny awake and keep awake for Google Play services
    Unsync Google services you do not need such as Google Newsstand, etc.
    Deny location for apps that ask for it a lot but do not use it, such as the Bleacher Report Team Stream app
    Install Leandroid (disables mobile data and Wi-Fi for 60 min and re-enables for 60 sec to check for notifications) and combine with power save performance profile
    Set apps that refresh in the background to never or for longer period of time than
    Keep brightness at or below 50% unless when in direct sunlight
  4. PyroManya77
    Donut Oct 26, 2014
    PyroManya77 , Oct 26, 2014 :
    yeah sadly, at least there are some good tips
  5. Adapting
    Adapting , Oct 26, 2014 :
    Genius hahaha
  6. dwaynelson
    KitKat Oct 26, 2014
  7. RickyWars1
    RickyWars1 , Oct 26, 2014 :
    Just curious, what actually happens when you do this?
  8. SirScotty
    Froyo Oct 27, 2014
    SirScotty , Oct 27, 2014 :
    I was just being silly.... Here in the US, we have 110 for standard household current. a dryer in the laundry room runs on a 220 line. I did tech support many years ago for a large computer company. We had an inside joke that when stupid people call us, we were going to tell them to plug their computer into the 220 line to speed it up. Luckily the plug for a clothes dryer is WAY bigger than the standard 2 or 3 prong household plug, so it will not fit. I am sure it would disable whatever you plug in to it by feeding it 2x the voltage that it is expecting.
  9. julien.longo
    Eclair Oct 27, 2014
  10. Flunkyo
    Cupcake Oct 27, 2014
    Flunkyo , Oct 27, 2014 :
    I think the battery life is pretty good as it is (every phone could need a better one but I last almost 2 days).
    There are really good apps, my favourite one is a customised ultra power saving app where you can actually decide which apps you would like to use (similar to the Ultra Power Saving Mode on Galaxy S5)
  11. emilycloud
    Gingerbread Oct 27, 2014
    emilycloud , Oct 27, 2014 :
    Turn down screen brightness, turn off sync, location, wifi when not in use.
    Use BetterBatteryStats to see what apps are using the most power and delete them.
    Use Greenify to hybernate apps that hog battery.
  12. Haters_Gonna_H8
    Ice Cream Sandwich Oct 27, 2014
