5
BGMI ( indian verison of PUBG ) lag and FPS locked . via OnePlus 8
  1. G_AKASH_MISHRA_xrag , via OnePlus 8 , Jun 18, 2021 :
    The new version of PUBG that's battle grounds mobile india is having lots of issue like fps is locked at 60 fps even when there is in-game option to play on 90 fps . OnePlus needs to unlock 90 fps for Battlegrounds mobile india and fix the lag issue . Hope to get a reply Thanks .
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 18, 2021
  3. Farhan_Fr
    Cupcake Jun 19, 2021
    Farhan_Fr , Jun 19, 2021 :
    Same issue, hope it will be fixed soon. Akash let me know if it's fixed for you.
    Thanks
    G1581699797762 likes this.
  4. G_AKASH_MISHRA_xrag , via OnePlus 8 , Jun 19, 2021 :
    No it's not fixed yet . OnePlus doesn't even no that this problem exists . [e]1f62d[/e]🥲
    siddharthmohanty likes this.
  5. Praty_28
    KitKat Jun 19, 2021
    Praty_28 , Jun 19, 2021 :
    OnePlus is already having a hard time fixing their messed up OS updates, I doubt that they even have time to look into trivial matters like these. Your best bet would be to contact the BGMI devs and hope that they optimize it for OnePlus devices.
  6. Farhan_Fr
    True but there's no response from BGMI too, its been 2 days already. Anyways bgmi is still in beta testing so it will be fixed anytime soon.
  7. _hidd3n_mist__
    _hidd3n_mist__ , via OnePlus 8 , Jun 19, 2021 :
    Ya having same issue even after changing refresh rate to 90 it doesn't run on 90Fps even in game option it mentions 90....But really it doesn't feel like 90 FPS.......
    IS IT BGMI PROBLEM OR WHAT ONEPLUS PROBLEM any idea though?
  8. O1624158802581
    Cupcake Jun 20, 2021
  9. Vikas Sharma 7T
    Honeycomb Jun 20, 2021
    Vikas Sharma 7T , Jun 20, 2021 :
    I don't think BGMI developers can do anything if OnePlus's oos doesn't allow apps using surfaceview to run more than 60 fps. BGMI has 90 fps feature enabled for OnePlus devices (7 pro, 7T, 8) but oos locks the maximum fps at 60 only. Anyway let's continue blaming app or game developers when the actual problem is oos itself. Please have a look at this: https://www.xda-developers.com/oneplus-7-pro-true-90hz-display-mode/
  10. Vikas Sharma 7T
    People be like I won't check anything before suggesting solution. Just blame app or game developer for everything. OnePlus will not do anything.
    PS: No offense please. For further support to my above claims, Please have a look at this screenshot from BGMI running on my OnePlus 7T. Can't check with fps meter as I don't have it but you can definitely see the refresh rate. Screenshot_20210620-091249_db2300be643d553259cbc11cd691d2a5.jpg
  11. Vikas Sharma 7T
  12. Farhan_Fr
    Farhan_Fr , via OnePlus 8 , Jun 20, 2021 :
    Vikas are you sure your game feels like 90 fps after entering the command ? is it compatible with oneplus 8 too?
  13. G_AKASH_MISHRA_xrag , via OnePlus 8 , Jun 20, 2021 :
    Man that 90 is not the FPS it's showing the 90hz that your phone is set too fps is a whole different thing OnePlus has locked it to 60 fps for BGMI and pubg KR version they need to unlock it . There will be option in-game to put it on 90 fps as bgmi knows that OnePlus supports 90 fps but even if u put it on 90 the game will still in reality run on 60 fps because it's locked to go above that for the BGMI . Play pubg global at 90fps and then play bgmi at 90 fps you will see the day and night difference .[e]1f44d[/e]
    Ani_mess and Farhan_Fr like this.
  14. Vikas Sharma 7T
    I didn't check with fps meter but you can see refresh rate and yes the smoothness is like global version. Please give me some time to record a video which I post here so that you guys can judge yourself 😅.
  15. Vikas Sharma 7T
    You didn't understand my point, do you? I hope this further clarifies your doubt. I know that's refresh rate
  16. Farhan_Fr
    Exactly !
  17. #17
    F1610082331177 likes this.
  18. G_AKASH_MISHRA_xrag , via OnePlus 8 , Jun 20, 2021 :
    Don't you think if it's really showing you the game fps then it should fluctuate a bit and not constantly show 90 fps ?
    To get real time fps you need to do lot of process .
  19. Vikas Sharma 7T
    Enjoy waiting brother. I have waited for around 1 year and 9 months approximately for OnePlus to unlock 90 fps option in dead trigger 2, modern combat versus, gear. Club. All these games have 90 fps enabled from developers but on OnePlus they run at 60 fps maximum
  20. G_AKASH_MISHRA_xrag , via OnePlus 8 , Jun 20, 2021 :
    What did you do ? You know any modifications you make by yourself with the game files can but you too permanent ban .
