181
BIG camera news on Color OS Camera
  1. Manico
    Honeycomb Feb 22, 2015
    Manico , Feb 22, 2015 :
    What file manager did you use plz
  2. don-doe
    KitKat Feb 22, 2015
    don-doe , Feb 22, 2015 :
    Stock file explorer should be fine. I use ES Explorer. You have to allow installation of apps from unknown sources in settings / security
    TheJames likes this.
  3. ULTIMATE2015
    Gingerbread Feb 22, 2015
  4. derino
  5. TheJames
    Jelly Bean Feb 22, 2015
    TheJames , Feb 22, 2015 :
    No the one I reccomend are the only very stable ones
  6. BobbyTC
    BobbyTC , Feb 22, 2015 :
    Now that Beta 4 is out does Beta 3 need to be uninstalled or does 4 install over it?
  7. jan110968
    jan110968 , Feb 22, 2015 :
    U need to uninstall first or u will get error
  8. Wackencorpse
    KitKat Feb 22, 2015
    Wackencorpse , Feb 22, 2015 :
    That is not correct. I didn´t uninstall Beta 3 and I got no problems installing Beta 4.
  9. royz0r
    royz0r , Feb 22, 2015 :
    the oneplus has a 13mp camera, so how can you make a picture with 50mp if youre camera is only 13mp?
  10. ULTIMATE2015
    ULTIMATE2015 , Feb 22, 2015 :
    me as well.. Beta 4 works great over my already installed Beta3
  11. Android the Greek
  12. ULTIMATE2015
    YES!! Its FRIGGN amazing. LOVE IT!! Thanks to all involved making this whole camera thing work!!
    HAPPY..HAPPY.. HAPPY!!
    Just think, last week I was going to toss the OPO in the garbage cause of retarded update..Did some reading and turned EVERYTHING around!!
    Android the Greek and TheJames like this.
  13. TheJames
    It takes ten 13mp images chooses the best ones and use software to make one 50mp image and it works.
  14. don-doe
    KitKat Feb 22, 2015
    It takes 10 shots at a time and uses the best 4 to interpolate the final image
  15. jan110968
    Well it woultn on mine hade to uninstall old one first
  16. Android the Greek
    Android the Greek , Feb 22, 2015 :
    Feel the same way! I was torn between the cm12 camera which had no features and the 11s that had bad processing. Happy with the oppo camera
    ULTIMATE2015 likes this.
  17. kraasz
    kraasz , Feb 22, 2015 :
    Do you have any APP for 4K video?
    Any App that allows manual setting in video?
    Really need those!
  18. chapelblade
    Cupcake Feb 22, 2015
    chapelblade , Feb 22, 2015 :
    Downloaded beta4. Focus does not seem as good as previous versions. Seems laggy, slow and not as sharp. Unroofed cm11 05 version.
  19. TheJames
    4k is built in, professional mode has manual controls.
  20. kraasz
    No it does not :)
    What's 'professional mode"... haven't found anything where I can control EV and LOCK exposure in 4K video!
    EDIT: I know it has 4K video, Look at our 4KOPO.com blog.
    What I am asking is manual control where you can lock exposure and so on.
    If you know there is one built in please explain where is it hidden :)
