Blank notification sounds via OnePlus 6T
  1. aadnan181
    Cupcake Apr 11, 2021
    aadnan181 , via OnePlus 6T , Apr 11, 2021 :
    Once in a while I get these blank notification sounds (notification sound with no actual notification). Very annoying as I have to check my phone just to see there's actually no notification. I checked the Notification settings and I noticed this "Enable Read mode notification for Manga rock". I uninstalled the app "Manga Rock" long time ago. Why's it still showing and that too in system's notification?!
  2. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 11, 2021
    Caoimhín , via OnePlus 6T , Apr 11, 2021 :
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    ⚠️This will not delete your apps data but you will have to provide permissions for all your Apps again.⚠️
    Check if this can help.
  3. drmartin
    Moderator Moderator Apr 11, 2021
    Caoimhín likes this.
  4. aadnan181
    Cupcake Apr 16, 2021
    aadnan181 , via OnePlus 6T , Apr 16, 2021 :
    Thanks a lot brother! Will try this and let you know if it worked.
  5. Raza_Dawar
    Gingerbread Apr 16, 2021
