3
Battery/Charging Blue LED while charging
  1. masi0
    Gingerbread Dec 10, 2016
    masi0 , Dec 10, 2016 :
    Seems there is an option to customize LED color for various cases, e.g. while charging, etc
    I set mine to orange yet it is still lights in blue. Is that a bug or I am doing it differently? :D
  2. Hadowken
    Cupcake Dec 10, 2016
  3. insulaz
    insulaz , Dec 10, 2016 :
    The light will turn blue when it's DASH charging. I guess it's a default set-up that you can't change.
  4. turist
    Eclair Dec 10, 2016
    turist , Dec 10, 2016 :
    One thing that really annoys me is that the red led will start blinking if the battery is low... I've been trying to turn it off but all I can do is change the color... It is really annoying because the red led over rides all other leds (like messenger's green ones)
  5. mishbah.islam
    Donut Dec 21, 2016
  6. Bartnl
    Lollipop Dec 21, 2016
    Bartnl , Dec 21, 2016 :
    Because it is a warning! And warnings are always red and overrule everything else.
    It's standard android
  7. Fi3
    Cupcake Dec 21, 2016
  8. bhavzi
    Cupcake Dec 22, 2016
    bhavzi , Dec 22, 2016 :
    Correct.. Blue is for Dash Charge.. i've also noticed it turns green when 100% charged.
    However, i've noticed there is an option to choose a Light color for different type of notifications available in Whatsapp settings.
    Open Whatsapp - Settings - Notifications - and see an option called Light which allows you to select one of the many colors available.
    I haven't been able to get it to work though, but there is an option to chanve the LED color...
  9. Chvrche5
    Cupcake Dec 24, 2016
  10. singheshant
    Donut Dec 24, 2016
    singheshant , Dec 24, 2016 :
    I was also bugged with this, but pretty soon realised, blue led is default for Dash charging. No complaints- Dash Charging makes other fast charging look slow
  11. trungtran11
    trungtran11 , Dec 24, 2016 :
    Dash charging makes the LED Light blue. If you were to use another USB-C type charger other than OnePlus' own, then it would be orange :). But i still recommend dash charging cause its fast af
  12. Kutbi1678
    Donut Dec 25, 2016
  13. G_HariPranav_Dharmalinga
    Cupcake Jun 13, 2017
  14. annjuan18
    Eclair Jun 14, 2017
    annjuan18 , Jun 14, 2017 :
    do you use dash charger? or using any third LED app?
  15. G_HariPranav_Dharmalinga
    Cupcake Jun 14, 2017
    G_HariPranav_Dharmalinga , Jun 14, 2017 :
    I am using the charger that came in the box. and no led app. Do you think there's something wrong with the charger?
  16. F_Diganta_Koner_WIXu
    Jelly Bean Jun 14, 2017
  17. F_Diganta_Koner_WIXu
    F_Diganta_Koner_WIXu , Jun 14, 2017 :
    That means it's charging slow not dash charging.
  18. G_HariPranav_Dharmalinga
  19. Harish Chary Valaboju
    Donut Jun 14, 2017
  20. shekar007
    Gingerbread Jun 14, 2017
    shekar007 , Jun 14, 2017 :
    while charging less than 50 it shows which colour u select after 50percent it turns into blue which indicates your phone has minimum charging...
