Blue tooth problems via OnePlus 5T
  1. Colinnoor
    Cupcake Oct 24, 2021
    Colinnoor , via OnePlus 5T , Oct 24, 2021 :
    Hi I am have some blue tooth problems with my 5T , some times it's connecting and sometimes it's not. You will find that it's showing connected to the buds but the sound is coming from the actual phone and not the bud. Sometimes it works just fine, can anyone help me please...... thanks
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 31, 2021
    Shailender Sharma likes this.
  3. U1637827128835
    Cupcake Nov 25, 2021 at 1:07 PM
    U1637827128835 , Nov 25, 2021 at 1:07 PM :
    I am having the same blue tooth problems. Sometimes it works and sometimes it doesn't. It won't recognize my watches. It will stream in the cars...for a while...then it fails and won't return. This phone has been problematic from the beginning. I don't think it was ready for release.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Nov 25, 2021 at 2:00 PM
    Caomhin , via OnePlus 9 Pro , Nov 25, 2021 at 2:00 PM :
    Reset your Bluetooth Network adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also try the following. If the option is available to you.
    Disable "Sleep Standby Optimisation " in the
    Settings, Battery, Battery Optimisation, 3 dots menu top right, Sleep Standby Optimisation.
    Re-start your device. This may also help.
