Bluetooth and file transfer issue in 4.1.3
  1. Adeel81a
    Gingerbread May 13, 2017
    Adeel81a , May 13, 2017 :
    Sometimes the Bluetooth is working very slowly like if i press the device to which data to be shared the phone isn't showing nothing and initialize transfers after a while.
    If i download anything or move data from the phone while it is connected to the pc in file transferring mode the download/moved data isn't visible in respective folders. Even after refreshing, reconnecting, reboot data isn't visible. But i can see is through native file manager app. But after a while data is visible
    Ps:do not recommend clearing cache n restore its been done already
    F_Shajahan_Shaik_sIhQ likes this.
  2. Crystal_Wang
    Donut May 16, 2017
  3. TheMystic
    Lollipop May 16, 2017
    TheMystic , May 16, 2017 :
    why are you using Bluetooth? you have much better and faster technology today. SHAREit is very good and available on all platforms. although it may be inconvenient to use just to transfer one or two small files.
    Adeel81a likes this.
  4. TheMystic
    alternatively, you can install folder sync app from JR Mobile Studio (Cheetah Sync) from Google play store and it's desktop software on your PC. with this, you can automate your phone Backup process too. much faster than Bluetooth.
  5. amitssj
    Honeycomb May 16, 2017
  6. Kr.m0hit
    Cupcake May 16, 2017
  7. F_Shajahan_Shaik_sIhQ
    Froyo May 16, 2017
    F_Shajahan_Shaik_sIhQ , May 16, 2017 :
    I'm having the same problem. I'm almost always connected to my Bluetooth speaker and it cracks up sometimes.. never had this issue on my Nexus
  8. Adeel81a
    Gingerbread May 19, 2017
    Adeel81a , May 19, 2017 :
    Phone to pc
  9. Adeel81a
  10. Adeel81a
    Thanks but you cant connect your ur Bluetooth headset via wifi, come on man.. Thax anyway
  11. TheMystic
    Lollipop May 19, 2017
    TheMystic , May 19, 2017 :
    I thought you were limiting the problem to transferring files. streaming over Bluetooth not included.
  12. Adeel81a
    [e]270c[/e]️
  13. Crystal_Wang
    Donut May 24, 2017
    Crystal_Wang , May 24, 2017 :
    I never do it with bluetooth. As far as I'm concerned, Apowersoft Phone Manager can help to transfer files from phone to PC and vice versa. You just need to download the app on your computer, and then connect your phone to PC via USB cable or WiFi. Then you can manage your files freely.
    [​IMG] ;)
  14. Arai
    Honeycomb May 24, 2017
    Arai , May 24, 2017 :
    If/when you're on Wi-Fi on both phone and PC, you can use Wi-Fi connection to transfer files. It doesn't even need to connect to the internet.
    Just use File manager -> File dash
  15. Arai
    OP3 File manager already have the functionality build in.
  16. Adeel81a
    Gingerbread May 24, 2017
    Adeel81a , May 24, 2017 :
    How do i use it with pc, i mean pc has needs a qr reader ryt?
  17. Arai
    You can use browser instead:
  18. Arai
    To explain: File dash uses your phone hotspot (without needing to use mobile data) to send files to your PC. Your PC can get it through browser.
    The down side being, if you used to use your phone hotspot to connect to the internet from other device, it shuts down the internet connection. You'll have to reboot the phone to reuse it as internet hotspot.
