Bluetooth Audio Codec issue via OnePlus 5
  1. Gughan.D
    Froyo Oct 23, 2019
    Gughan.D , via OnePlus 5 , Oct 23, 2019 :
    Hi all,
    I enabled the AAC audio codec in my OnePlus 5 in the developer options menu while connecting to my Bose Soundlink revolve (supports AAC, I checked). But it reverts back to SBC everytime. Any tips on how to enable it permanently while it remains connected to the speaker?
  2. Malg220
    Ice Cream Sandwich Oct 23, 2019
    Malg220 , Oct 23, 2019 :
    Your device has chosen the best compatible codec for the bose revolve:
    Gughan.D likes this.
  3. Malg220
    Bose has good amplified sound, but has a bad habit of hiding its technical specifications in its products, it's hard to know the bluetooth codec, transfer rates, etc.
  4. Gughan.D
    Froyo Oct 23, 2019
    Bose does that. I specifically asked Bose technical support if it supports any other codecs other than SBC. I was told that it supports only SBC and AAC. But if the device chose the codec based on the quality of audio, then I have no option. Thank you so much.
    Malg220 likes this.
  5. StopItRawr
    Honeycomb Oct 23, 2019
    StopItRawr , Oct 23, 2019 :
    https://www.soundguys.com/the-ultimate-guide-to-bluetooth-headphones-aac-20296/
    The biggest concern with AAC is its hugely variable performance between smartphones. Even Bluetooth’s default SBC didn’t see anything approaching this variety between phones I’ve tested. If you’re an Android user, you’re probably better off sticking with SBC, or opting for aptX or LDAC if available.
    In all honest, the device has probably selected the better option.
  6. Gughan.D
    Froyo Oct 23, 2019
    Agreed. Thank you!
  7. R1540918460950
    Cupcake Nov 1, 2019
    R1540918460950 , via OnePlus 6T , Nov 1, 2019 :
    I am facing similar issue.... I have sony 1000mx2 which support LDAC... Developer Bluetooth options doesn't stick when changed... Does anyone how do we take this issue to oneplus support?
  8. Gughan.D
    Froyo Nov 2, 2019
    Gughan.D , via OnePlus 5 , Nov 2, 2019 :
    Try reporting a bug. It might help.
