Bluetooth audio codec
  1. Sahuu7
    Eclair Dec 1, 2017
    Sahuu7 , Dec 1, 2017 :
    So yeah.. which one i should use as BT audio codec; Bluetooth default codec or just pick the aptX codec in dev. settings? Also is there any difference between compability and stability? i know that aptX should improve audio quality.
    Thanks for advice! [e]1f44d[/e]
  2. Xavierpony
    Gingerbread Dec 1, 2017
    Xavierpony , Dec 1, 2017 :
    depends on wether on not the Bluetooth device supports. I would recommend setting it to aptx hd and it will autoselect depending on device
    Sahuu7 likes this.
