Bluetooth Automatically Switch On Issue
  1. F1541686969565
    Cupcake Apr 16, 2020
    F1541686969565 , Apr 16, 2020 :
    Hello Team,
    I am facing some bug in my one plus 6T , my phone automatically switch on the blue tooth. even I turned it OFF.
    Please let me know if anyone have solution.
    C1573568497745 likes this.
  2. F1541686969565
  3. Priyanshu Sharma
    Jelly Bean Apr 16, 2020
    Priyanshu Sharma , Apr 16, 2020 :
    Phone and Network then Bluetooth.. I think any app is turning it on.. Have you installed any app after that it's happening?
    Try this- Press and hold on Bluetooth icon in Quick settings panel then click on scanning settings and turn off Bluetooth Scanning and see if it occurs again or not.
    Artemus. likes this.
  4. V1552310489210
    Cupcake Apr 18, 2020
  5. V1552310489210
    Cupcake Apr 19, 2020
    V1552310489210 , Apr 19, 2020 :
    got it solved. i have deleted last 3 recently installed apps. and it worked. now bluetooth doesnt turn on automatically.
    ronaksworld likes this.
  6. ronaksworld
    Jelly Bean Apr 19, 2020
    ronaksworld , Apr 19, 2020 :
    You can try the solution mentioned by @V1552310489210, if not then few days ago i had posted the solution for similar issue try to search it.
  7. RichEMPIRE
    Cupcake Dec 12, 2020
    RichEMPIRE , Dec 12, 2020 :
    I found out why it was happening to me.
    Uber Eats was turning on the Bluetooth.
    I just uninstalled it.
  8. rouge02
    Froyo Jul 18, 2021
    rouge02 , Jul 18, 2021 :
    A possible solution that worked for me was going to the Wi-Fi and Bluetooth Scanning setting, then disable Bluetooth Scanning.
    In the description it even says that it will automatically scan nearby Bluetooth devices even if your your Bluetooth is off (it does this by turning it on automatically).
  9. mallickcs
    Cupcake Jul 20, 2021
    mallickcs , Jul 20, 2021 :
    yes, Uber Eats is the culprit..after uninstalling the Uber eats and restarting the phone, the problem disappeared..
  10. Pranay1402
    Cupcake Jul 23, 2021
  11. kamashbg
  12. L1627839485617
    Cupcake Sep 8, 2021
    L1627839485617 , Sep 8, 2021 :
    I am facing some bug in my one plus 9R , my phone automatically switch on the bluetooth. even I turned it OFF.
