Bluetooth battery indicator
  1. G_Sopheakrith_Koungkea_O
    Eclair May 21, 2018
    G_Sopheakrith_Koungkea_O , May 21, 2018 :
    lately, I heard there is Bluetooth battery indicator in Android 8.1.by the way, now i connect beatx with OnePlus 5. there is still no indicator as well. anyone experience this problem?
  2. Gav_W86
    Starting Point Expert May 21, 2018
    Gav_W86 , May 21, 2018 :
    depends on whether the headphones support it - its a Bluetooth version thing I believe. My Sony WH100XM2's show it.
  3. G_Sopheakrith_Koungkea_O
    Eclair May 21, 2018
    can I see that screenshot?
  4. the_o2
    Marshmallow May 21, 2018
    the_o2 , May 21, 2018 :
    Its shows battery percentage in the bluetooth section not in the status bar, I guess...
  5. Gav_W86
    haven't got them with me, will try and remember later.
    shows in both the status bar and the bluetooth section of settings.
  6. G_Sopheakrith_Koungkea_O
    Eclair May 21, 2018
    anyway, thank for info brother.
  7. pa5t1s
    pa5t1s , May 21, 2018 :
    your Bluetooth (LE) device must implement this service to be able to see it.
  8. saad1957
    Jelly Bean May 21, 2018
    Gulams likes this.
  9. saad1957
    saad1957 , May 21, 2018 :
    shows only on Bluetooth settings.
  10. Gav_W86
    there is a little battery icon next to your Bluetooth status bar symbol in that screenshot...
  11. Gav_W86
    Next to the Bluetooth symbol in the status bar
  12. saad1957
  13. Gav_W86
    the original poster wasn't...the original post said "I heard there is Bluetooth battery indicator"
    Budruel likes this.
  14. saad1957
    ok , maybe we are both right .
  15. soumava91
    Cupcake Jul 25, 2019
    soumava91 , Jul 25, 2019 :
    In case someone is not able to view even the indicator icon (not talking about the %), one might try switching off 1-2 indicators. The Bluetooth battery indicator on my phone started showing up after I turned off the voLTE indicator.[​IMG]
    Budruel likes this.
  16. N1557935596649
    Cupcake Aug 18, 2019
    N1557935596649 , Aug 18, 2019 :
    I have the same issue with My Samsung Level U Bluetooth headset. Same device is being used in Op 7 showing the battery indicator, but not in my Op 6t.
    Is there solution for this issue?
  17. Budruel
    KitKat Aug 18, 2019
    Budruel , Aug 18, 2019 :
    This has worked for me. If you have 2 bluetooth devices connected you will not see the loading bar of your device, with only one connected yes.
