3
Bluetooth Calling
  1. Petjitsu
    KitKat Aug 19, 2019
    Petjitsu , Aug 19, 2019 :
    unfortunately, it requires root authority :(
    and unlocked bootloader
    Sid 2586 likes this.
  2. D1564854384420
    Donut Aug 21, 2019
    D1564854384420 , Aug 21, 2019 :
    Hi, Pejitsu! I tried exactly your scheme. Did not help. What bitrate did you choose when installing the Bluetooth stack audio bitrate changer module? During installation, you must press the volume key and select: 451, 456, etc.
  3. Petjitsu
    KitKat Aug 21, 2019
    Petjitsu , Aug 21, 2019 :
    try
    If something is not working - just re-install the module with new bitrate or uninstall it completely.
    I have no idea if installing this module fixed the problem
    but in my case everything works fine
    need to experiment ;)
    Good luck
