2
Bluetooth car audio song information not displayed
  1. hexigen
    Cupcake Dec 3, 2015
    hexigen , Dec 3, 2015 :
    That's exactly what I saw, nothing worked on OnePlus X except one way streaming. Try truedialer and see if it helps, like it helped me.
  2. Haze1990
    Froyo Dec 4, 2015
    Haze1990 , Dec 4, 2015 :
    Every other phone i have used as worked as well which is why i suspected OP as you do but was told it was Lollipop.
  3. ukanth
    Eclair Dec 4, 2015
  4. twinturbopoweredz
    Gingerbread Dec 5, 2015
  5. OnePlusVarma
    OnePlusVarma , Dec 5, 2015 :
    I think this bug should be considered for the next fix. Why do we have to install so many other apps to just play songs in the car?? It should work seamless out of the box.
  6. smersh71
    Froyo Dec 5, 2015
    smersh71 , Dec 5, 2015 :
    These issues sound bad for me.
    Just ordered the OPX and I'm a delivery driver and I rely on Google map and stream Google play through the bluetooth system in my '14 Ford transit.
    It sounds like some of these problems are in cars with a navitainment system. I hope this is the case (no offence) as my van doesn't have one of those. Sorry that sounds selfish. But I'd be lost without the bluetooth functionality, literally & figuratively.
    I use this app and have done for years now,
    https://play.google.com/store/apps/details?id=spinninghead.carhome&hl=en_GB
    Simple and very customisable.
  7. Vomitis
    Gingerbread Dec 12, 2015
    Vomitis , Dec 12, 2015 :
    My opx doesn't show song or track info either in my 2013 vw beetle. Phone book and calling all show up and works fine. Music plays you just can't see what's playing on the car stereo.
    Everything works the way it should on my kenwood kdc-797.
  8. anast68
    Cupcake Dec 19, 2015
    anast68 , Dec 19, 2015 :
    The same happens to me, my pioneer DEH-X5500BT doesn't show track info.
  9. rodge
    Cupcake Dec 20, 2015
    rodge , Dec 20, 2015 :
    I have the same problem with the same radio..
    Works fine with my old Nexus 5.
  10. Johnangangan
    Eclair Dec 20, 2015
    Johnangangan , Dec 20, 2015 :
    Same here doesn't show track info but can change track from buttons on headunit but it also lights the screen when you change track too
  11. anast68
    Cupcake Dec 26, 2015
    anast68 , Dec 26, 2015 :
    Here is the answer from the Tech Support:
    Janny
    Yesterday at 22:14
    Hi
    Good day! I am sad to say that you cannot view the tracks into the your car's stereo because the file really is not really from your car's stereo but from the phone you are using to connect. But still you can view the tracks on your phone of course.
    Hope this helps. Let me know if you have any other questions.
    Best regards,
    Janelyn
  12. rodge
    rodge , Dec 26, 2015 :
    Of course the files are on the phone. But the phone is connected to the stereo via bluetooth and should display the track info, not only "E1003".
    I had no problem on my old Nexus 5.
    Using Spotify on both devices.
    It must be a software bug.
  13. jameswgmoore
    Cupcake Dec 28, 2015
    jameswgmoore , Dec 28, 2015 :
    Xo
    I couldn't agree more. I've just switched to a OPX from a Nexus 5 and I'm having real problems with Bluetooth car connectivity (complete opposite experience from my Nexus).
  14. wlmoate
    Cupcake Jan 3, 2016
    wlmoate , Jan 3, 2016 :
    Hi,
    I do not get track names on my BMW, if I use a iPhone or a Samsung S6, I do get the track name. I used to get the track name from a OnePlus One before updated to the latest firmware.
    When will this be fixed?
    Wayne
  15. prezes5
    Ice Cream Sandwich Jan 3, 2016
    prezes5 , Jan 3, 2016 :
    I'm thinking it might be the "metadata" tags on the files themselves. You would have to edit your mp3's so all the fields are complete. My Pioneer touchscreen head-unit can't see some files either. Just depends on the file, but I usually switch up my playlist often so I won't go editing files. Would take eternity.
  16. lehoon
    Cupcake Jan 23, 2016
    lehoon , Jan 23, 2016 :
    Got the same issue with my Parrot CK3100. BT connects but no contacts are being synced. This used to work on my OnePlus One running CM12.1.
    CM12.1 had the annoying issue of switching off the Contact Sync tick in the BT settings, but flashed it anyway on my OnePlus X just to make it usable in the car.
  17. anast68
    Cupcake Jan 24, 2016
    anast68 , Jan 24, 2016 :
    I installed CM.12.1 and finally the track info appeared in my pioneer DEH-X5500BT.
  18. lostLambda
    Lollipop Jan 24, 2016
    lostLambda , Jan 24, 2016 :
    Jesus H. Christ. It's 20-frickin-16!!!! Why do we still have all these trivial software problems!!! :mad:
    #38
  19. Firefly1337
    Froyo Jan 24, 2016
    #39
  20. exoduscj
    Eclair Apr 4, 2017
    exoduscj , Apr 4, 2017 :
    So I have to change the car to be supported by the phone :) .
    #40
