[Submitted] Bluetooth connection to car
  1. familiamay
    Cupcake Sep 2, 2018
    familiamay , Sep 2, 2018 :
    Connecting to Bluetooth in the car while listening to music or audiobook, if I try to make a phone call, Bluetooth won't connect. Then go back to music or audio, it keeps skipping. I have to shut phone down and completely restart.
  2. amughal1
    Cupcake Sep 3, 2018
  3. NiKuchroo
    Cupcake Oct 11, 2018
    NiKuchroo , Oct 11, 2018 :
    I have the same issue as well. In my OP5's bluetooth menu (long press my car's system name) i'm unable to check the phone option. It worked like a charm on the first connect (and whenever i delete the devices and re-discover).
    I'm facing an issue in connecting my phone to car's smart infotainment system. I have a Suzuki equipped with a smart-play system that supports android auto. The phone links via Android auto with usb and Bluetooth. I have no problems in accessing contacts messages maps. But, the phone feature is not available
    If I dial out, the audio is from the phone. Phone is not audible in car Stereo. This is true if I use Bluetooth only or usb to connect. In the Bluetooth options I see phone as unchecked but I'm not able to enable it.
  4. NiKuchroo
    Cupcake Oct 12, 2018
