Bluetooth connectivity issue in my OnePlus 6t.
  1. Kamelia Roy
    Cupcake Dec 14, 2019
    Kamelia Roy , Dec 14, 2019 :
    I'm facing Bluetooth connectivity issue in my OnePlus 6t. Headphones are getting connected successfully with the Bluetooth but sound is coming from the speaker. Again when I'm disconnecting the headphones, the sound is getting muted. Anyone else facing the same?
    Caomhin likes this.
  2. Caomhin
    Jelly Bean Dec 14, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 14, 2019 :
    You could try resetting Bluetooth, however this will also reset WiFi, you will have to re login to WiFi with your credentials.
    Go to Settings, System, Reset Options to access Bluetooth reset option. You will also have to re pair all Bluetooth devices.
  3. F1575841062388
    Cupcake Dec 15, 2019
