2
OxygenOS Bluetooth connectivity issues
  1. borse2008
    Eclair Jan 10, 2017
    borse2008 , Jan 10, 2017 :
    So noticed after moving to Nougat need to test 4.0.1, i use bluetooth wireless earphones even after ive connected the device to my headphones audio playback dosent automatically playback. A bug ?
    jerchen and G_Tommy_Haywood_WrES like this.
  2. Dalinian61
    Donut Jan 11, 2017
    Dalinian61 , Jan 11, 2017 :
    Hi Borse, I've also upgraded to OxygenOS v4.0.1, and I've been using the same Bluetooth wireless earphones (Samsung HS3000) on OOS v3.5.4, v4.0, and v4.0.1 with no diminution in performance. When I switch on the Bluetooth wireless earphones controller, I hear "devices connected"; then when I play an audio output app (eg: CastBox, TuneIn Radio Pro, BBC iPlayer Radio), the audio comes through the Bluetooth wireless earphones, as expected.
    So I'd suggest that the problem you've encountered isn't a general bug affecting all Bluetooth wireless earphones on OOS v4.0.1.
    The only thing I could suggest (if you've not tried it already) is to unpair, and then pair all over again, your own Bluetooth wireless earphones, and see if that gets everything running smoothly again - here's hoping that'll fix it.
  3. G_Tommy_Haywood_WrES
    Cupcake Jan 11, 2017
    G_Tommy_Haywood_WrES , Jan 11, 2017 :
    I get shocking Bluetooth performance, before and after the update. OP3 and OP3T. No one acknowledges the issue. Must be hardware
    bharanidharan84 likes this.
  4. luker900
    Cupcake Jan 12, 2017
  5. dmarek1
    dmarek1 , Jan 12, 2017 :
    Same issue with my cars Bluetooth media streaming and only connecting and disconnecting several times temporarily fixes it.
  6. Maazperwez
    Honeycomb Jan 12, 2017
    DustpaN_Spb likes this.
  7. Anand Kochhar
    Cupcake Jan 13, 2017
    Anand Kochhar , Jan 13, 2017 :
    disappointed with Bluetooth connectivity issues, my Logitech headset 800 not able to connect with 3T (oxygenOS3.5.4)
  8. manuelsbecker
    Cupcake Jan 14, 2017
    manuelsbecker , Jan 14, 2017 :
    Does anybody know of bluetooth headset devices that definitely work with 3T? My Plantronics Explorer 50 is never even displayed...
  9. jerchen
  10. sitoi
    Cupcake Jan 27, 2017
  11. Pauli_de
    Pauli_de , Jan 27, 2017 :
    I also have trouble with bt-connection and car-radio. it dosen't work. I called today with the support. They told me, that after the next update these problems will be Ok. There are compatiblity-problems with car-radio and other devices.
  12. jerchen
    Cupcake Jan 29, 2017
    jerchen , Jan 29, 2017 :
    Hi got this info from support:
  13. musicking
    Froyo Jan 29, 2017
    musicking , Jan 29, 2017 :
    Better than what they told me.
    They told me to downgrade if I wanted it to work, or wait for a fix and no eta. They said they can't make it work with all BT devices
  14. ktulu3388
    ktulu3388 , Jan 29, 2017 :
    For the moment, never had problems with Bluetooth connection to my 2 cars and to Gear S2.
