2
[Submitted] Bluetooth does not auto-connect audio to vehicle after Android 11 update
  1. DangerSloth
    Cupcake Sep 14, 2020
    DangerSloth , Sep 14, 2020 :
    Since updating to the Android 11 OTB, my OP8Pro will no longer auto-connect as an audio source to my vehicle (2015 Jeep Grand Cherokee w/Unconnect 3C fully updated). I have to go into the settigns and manually connect to the car - though the phone portion conencts with no problem. What's weird is the phone connects, initially, shows the last track I was listening to, then it disconnects as an audio source.
    Bernaberu and carlos_ale like this.
  2. carlos_ale
    Cupcake Sep 15, 2020
    carlos_ale , Sep 15, 2020 :
    Same here, I have a Bluetooth audio receiver connected to my car audio and my OnePlus 8 with OxygenOS 11 Beta 1 is not connecting automatically when entering into the car. The previous OxygenOS 10 did it.
  3. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Sep 15, 2020
    Suhas Klkrn555 , Sep 15, 2020 :
    We may have to check this further. Kindly check you're inbox we've dropped you a direct message. It'll be of great help if you could share the required information.
    Thanks & Regards,
    Suhas.
  4. DangerSloth
    Cupcake Sep 16, 2020
    DangerSloth , Sep 16, 2020 :
    Suhas - I've messaged you with details, logs, and screenshots.
    Thanks so much for your help on this! It's great having you guys as a resource!
  5. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Sep 18, 2020
    Suhas Klkrn555 , Sep 18, 2020 :
    Thanks for the logs. I’ve passed on the information to the relevant team and will get back to you in case of any further updates.
    Thanks & Regards,
    Suhas.
  6. Bernaberu
    Cupcake Oct 27, 2020
    Bernaberu , via OnePlus 8 , Oct 27, 2020 :
    I have the same issue on OnePlus 8 after updating to Android 11. My truck will connect for calls but not for media playback. Has this issue been resolved?
    G_Andreas_Müller_pRiG and Amruh like this.
  7. Arpit_Phadnis09
    Cupcake Nov 10, 2020
    Arpit_Phadnis09 , via OnePlus 7T , Nov 10, 2020 :
    Those who are facing Bluetooth auto connect problem , try factory reset of your headphones and pair. I was also facing same issue with my jbl live 500bt. I did factory reset by pressing volume up and down buttons simultaneous.
  8. #8
    W1604446173545 likes this.
  9. G1613023044028
    Cupcake Feb 11, 2021
    G1613023044028 , Feb 11, 2021 :
    I am having the same issue. OnePlus 8 T-Mobile 5G. Just got the 11 update, and I cannot connect to my cause UConnect system. Other phones connect just fine still, so I know it's an issue with the phone. The phone can still connect to other Bluetooth devices just fine too. It ends up crashing UConnect and the whole screen turns black and restarts. I tried clearing bluetooth & wifi cache/storage to no avail. Re-pairing multiple times to no avail. Restarting both the car and the phone to no avail. Please provide a solution soon.
    N1564232171309 likes this.
  10. G1614858015605
    Cupcake Mar 4, 2021
    G1614858015605 , Mar 4, 2021 :
    I am having the same exact issue. Did you figure out how to fix it? If so could you share? It says there are 8 replies to this post but I can't read them for some reason. Please help if anyone can.
  11. G_István_Gelencsér_AxQ , via OnePlus Nord , Mar 10, 2021 :
    OP Nord update to Android 11 is solving every problem with Android Auto. Good Job
  12. N1564232171309
    Cupcake Apr 14, 2021
    N1564232171309 , Apr 14, 2021 :
    Hi! I have the exact same problem with my car. I have realized that if I manually goes to my bt-settings on my phone and connects the car right when I start the car it works most of the time. Basically. Don't let it auto-connect. I have tried to found a setting to turn that of but I haven't :/
  13. V1576144897285
    Cupcake Apr 26, 2021
    V1576144897285 , Apr 26, 2021 :
    I am having the same issue with my OnePlus 7 after android 11 update. My bluetooth receiver does not connect automatically now. Please help.
  14. J1569464889244
    Cupcake Apr 28, 2021
    J1569464889244 , Apr 28, 2021 :
    Same problem after Android 11 update. It took so long to get and now issues like this make me miss my Samsung.
  15. Rajiev
    Cupcake Oct 18, 2021
    Rajiev , Oct 18, 2021 :
    Having the same issue.
    Oneplus 7T pro.
    Had BT issues in my OP 5 too. Apparently OP is focusing more on profits and less on User experience now a days.
    This is my last Oneplus phone.
  16. threeta
    Cupcake Jan 23, 2022
    threeta , Jan 23, 2022 :
    Same issue here. Pulling hair out.
    Solved
    Go to Bluetooth and device settings
    Select Bluetooth
    Select settings for the device
    Turn on phone calls and contact sharing.
    Seems good now
    Turn on
