Bluetooth earphones not vibrating for incoming calls
  1. megh.srinivas
    Cupcake Jun 23, 2019
    megh.srinivas , Jun 23, 2019 :
    Hello all .. I have a oneplus 5t device and Boult Curve (neck band) bluetooth earphones. A feature of those earphones is that it should vibrate on the neck band for incoming calls. But this feature doesn't seem to be working for me. I have exchanged the earphones for a new one , but the problem remains so it might be some setting in the phone may be.
    Can u suggest any changes in settings or a quick fix ?
    sumitk@07 likes this.
  2. Waveform Modifier
    Marshmallow Jun 23, 2019
    Waveform Modifier , Jun 23, 2019 :
    Not the phone's issue. You should ask the earphone manufacturer.
    Muhsin_Sultan likes this.
  3. hero_2002
    Cupcake Aug 18, 2019
    hero_2002 , Aug 18, 2019 :
    Hey i having same problem i guess its phones problem
  4. CHINTAMANENI
    Cupcake Jan 22, 2020
    CHINTAMANENI , Jan 22, 2020 :
    I'm using one plus 6t I'm also using bolt curve my product is vibrating while incoming call..
  5. Waveform Modifier
    Marshmallow Jan 22, 2020
    Waveform Modifier , Jan 22, 2020 :
    Wrong forum
  6. sumitk@07
    Cupcake Jan 23, 2020
