Bluetooth error with my Skoda car
  1. BNSELIIM
    Cupcake Sep 12, 2018
    BNSELIIM , Sep 12, 2018 :
    suddenly, my phone started to lose connection with my car's infotainment system.
    a couple of month back after an update the car ringtone stopped to ring when there is an incoming call. now i can play music, but i fail to receive calls on handsfree even it fails to call.
  2. Dimbim23
    Froyo Sep 12, 2018
    Dimbim23 , Sep 12, 2018 :
    well, at least your phone can connect to the car. my phone absolutely useless
  3. Mr_Cyrox
    KitKat Sep 12, 2018
    Mr_Cyrox , Sep 12, 2018 :
    Why?
    Did it flip you off?
  4. Dimbim23
    Froyo Sep 12, 2018
    when I'm trying to connect it shows can't connect to the device. this is it.
  5. Mr_Cyrox
    KitKat Sep 12, 2018
    Clear cache from recovery...
    Clear cache and data from Bluetooth "app" from settings...
    Reset network settings...
    Also if a smartphone can't do one thing it doesn't mean it's useless...
  6. djmfire
    KitKat Sep 12, 2018
    djmfire , Sep 12, 2018 :
    Reset the cars infotainment system so it forgets the phone. Do the same to the phones Bluetooth so it forgets the car. Then pair from scratch. I had same issue with my ford ranger. It was only when I reset the cars system did everything work properly
  7. Dimbim23
    Froyo Sep 12, 2018
    Tried all options mate [e]1f609[/e] been reading that could be problems with car Bluetooth module witch not supporting rsap connection
  8. Dimbim23
    Froyo Sep 12, 2018
    any ideas how to reset car?
    U1520934438630 likes this.
  9. Mr_Cyrox
    KitKat Sep 12, 2018
    No...
    Next time reply to me not yourself ;)
    Just wait for OxygenOS 5.1.6...
    It may fix your problem also as Bluetooth is a challenge for OOS 5.1.5 as of now ;)
  10. Dimbim23
    Froyo Sep 12, 2018
    nothing changed sice i bought this phone and after many updates same shit [e]1f609[/e] crap phone
    X1517396854503 likes this.
  11. Mr_Cyrox
    KitKat Sep 12, 2018
    Buy a different phone then...
    One update that broke samething and phone out the window?
  12. djmfire
    KitKat Sep 13, 2018
    djmfire , Sep 13, 2018 :
    I went into the cars setting and one option was to reset the whole system. Took a while to find it in the menu but it worked
  13. X1517396854503
    Honeycomb Sep 13, 2018
    X1517396854503 , Sep 13, 2018 :
    Which Skoda to be precise? I am asking this because some models got the infotainment software update but that has nothing to do with the Bluetooth issue I guess.
  14. BNSELIIM
    Cupcake Oct 4, 2018
    BNSELIIM , Oct 4, 2018 :
    i think it works now after network reset. thanks a lot.
    the issue now is that car ringtone doesnt work, my phones ringtone sounds on cars speakers only :)
  15. Dimbim23
    Froyo Oct 4, 2018
    Dimbim23 , Oct 4, 2018 :
    skoda superb 09
  16. BNSELIIM
    Cupcake Oct 13, 2018
  17. Prateek Kejriwal
    Gingerbread Oct 13, 2018
    Prateek Kejriwal , Oct 13, 2018 :
    This is definitely an issue with the device. I have OnePlus 5 and I have the same issue with the following cars; Altis, Q7, Honda City, i10. My friend has OnePlus 6 and he too faces Bluetooth issues in his car.
  18. ojhaab
    Donut Oct 13, 2018
    ojhaab , Oct 13, 2018 :
    Guys same problem with me, I just reboot my phone couple of time its working fine now
