Bluetooth headphone volume decreased 9.5.10 update
  1. alanrushmore
    Gingerbread Jul 18, 2019
    alanrushmore , Jul 18, 2019 :
    Before 9.5.10 update, RHA trueconnect bluetooth volume was perfectly loud. Now after latest update 9.5.10, noticed volume was reduced.
  2. suhantm
    Ice Cream Sandwich Jul 18, 2019
    suhantm , Jul 18, 2019 :
    Same happened for my BW2 today, I just deleted the device from the Bluetooth settings and repaired them. they work perfectly fine now.
  3. cyayon
    Donut Jul 26, 2019
  4. DFranch
    Donut Jul 26, 2019
    DFranch , Jul 26, 2019 :
    When you adjust the volume of your headphones, does it adjust the volume on the device, or just the headphones? if it is adjusting the volume on the phone, there is a setting in developer options (if you have that enabled) to separate the bluetooth volume from the headset volume. I believe it is "disable absolute volume" you need to turn that off. afterward the bluetooth volume and headset volume are seperate.
  5. cyayon
    Donut Jul 26, 2019
    cyayon , Jul 26, 2019 :
    I have disabled "bluetooth absolute volume" in SOUND&VIBRATION/Earphone mode/ settings.
    When i adjust the volume on headphones, it does NOT adjust the volume on the device.
    In developper options menu "Disable absolute volume" is enabled (on).
    Do i need to turn OFF this option in developper menu ?
    thx
