Hi,
I am using one plus Nord mobile with current version 10.5.10
While using OnePlus Bullets Wireless Z, i am facing issue of Bluetooth disconnection while making or receiving call, Bluetooth status is showing connected, but unable to use Bluetooth while on call, same had been tried on another OnePlus Bullets Wireless Z & JBL Clip 3 Bluetooth,but still facing same issue.
this problem accure while using mobile is connected to WIFI, when mobile data is on then Bluetooth works smoothly.
I have troubleshooted the issue on connecting same blue tooth device on different one plus device 7 but not observed the issue on other device with lower version. I have already reset performed on Bluetooth device as well as used the setting reset mobile, wifi and Bluetooth setting.
Seems this is a software bug but not sure . I need to get read of this issue so please can some one share me the workaround or permanent fix for the issue?
this issue happened while pairing new BT device Boat RockerZ
