Bluetooth in the car
  1. moularyves
    Honeycomb Jan 26, 2017
    moularyves , Jan 26, 2017 :
    I recently bought a OnePlus 3T coming from a OnePlus One
    with my OnePlus One when I was on a call before entering the car it will hand off the call automatically to the car speakers and microphone but with the OnePlus 3T it will connect but not hand off, I have to select phone earphone or speakers and then back to Bluetooth before it effectively hands it off to the car.
    Anyone has experienced this?
  2. rloveman
    Eclair Jan 26, 2017
    rloveman , Jan 26, 2017 :
    Nope. Mine goes straight to Bluetooth and my car speakers as soon as I start my car, and then back to the phone when I turn the car off. Maybe a Bluetooth setting or something in your car?
  3. Emiliano_Cirillo
    Donut Jan 26, 2017
  4. cma4_
    Eclair Jan 27, 2017
    cma4_ , Jan 27, 2017 :
    My connects fine but, most times the volume is so low with the Bluetooth that I have to take it off and use it as a handheld
  5. moularyves
    Honeycomb Jan 27, 2017
    moularyves , Jan 27, 2017 :
    I immediately assumed it was the phone since my OPO was just fine. Anyway, thx for your inputs, I the hope to find a fix
  6. BladerzZZ
    Froyo Jan 27, 2017
  7. Andrii Romanenko
    Cupcake Jan 28, 2017
    Andrii Romanenko , Jan 28, 2017 :
    OP3T, A3010, Android 7
    Version of OS
    : Oxygen 4.0.2
    Model of Car: VW Tiguan 2008 (RNS510 + BT Harman/Backer 1Z0 035 729B)
    Description Issue: Can not connect Bluetooth, phone doesn't paired !
    someone has a solution to this problem?
  8. rishigadhok
    rishigadhok , Jan 28, 2017 :
    Mine connects if I turn the phones bluetooth off and on again. Similar issues with all Bluetooth devices. Headphones. Smart watch.
  9. Sologon85
    Sologon85 , Jan 28, 2017 :
    In my case its imposible to pair the car with my bluetooth
    Model of Car: Seat Ibiza
    Version of OS : Oxygen 4.0.2
  10. G_Adrian_Chiu_kyWY
    Froyo Jan 28, 2017
  11. Sela69
    Cupcake Jan 29, 2017
    Sela69 , Jan 29, 2017 :
    I have an Alfa Romeo Giulietta with Uconnect system and no issues with 4.0.2
  12. Shubham Sharma324c17
    Froyo Jan 29, 2017
  13. Dunnow
    The Lab - OnePlus 6 Reviewer Jan 29, 2017
    malidan likes this.
  14. nprime
  15. advait92
    Donut Jan 29, 2017
    advait92 , Jan 29, 2017 :
    Even I have to manually connect it at times, not always. But other than that, I have another issue. On Bluetooth, the call quality drops drastically, it sounds as if you are trying to talk under water. And this has happened only after switching to Nougat! Call quality was fine in Marshmallow.
    Also, did a factory reset but the issue persists. Additionally, I even tried connecting my friends phone, they seem to work fine!
  16. G_alfred_9394
    Eclair Jan 29, 2017
    G_alfred_9394 , Jan 29, 2017 :
    my Hyundai Tucson and one plus 3t paired up like they were buddies from a previous life. didn't even need to enter the stupid '0000' password for pairing. no issues at all.
  17. malidan
    Nougat Jan 29, 2017
    Dunnow likes this.
  18. gkellleher85
    Eclair Jan 31, 2017
    gkellleher85 , Jan 31, 2017 :
    I have an issue with a 16 plate 3 series. Since the Nougat update it connects most of the time but every 3 or 4 times it just wont connect. I have the remove the device in the iDrive system and then pair it again.
    Had a issue with my Nexus 6p when it was updated to 7.0 also. Bluetooth keep disconnecting randomly, was massively annoying. It was eventully fixed with the latest patch however my 3T delivered shortly after. Very annoying to again have bluetooth issue after the nougat update.
  19. F_DG_QnuW
    Cupcake Jan 31, 2017
    F_DG_QnuW , Jan 31, 2017 :
    My car is also not detecting my recently purchased phone (Honda Accord 2006)
    so I decided to buy a seperate handsfree kit, which also cannot connect to my phone :mad:
    My father in law also has problem pairing it to his sena handsfree
    p.s. my phone has oxygen os
    any Ideas ?
  20. sillybeans
    Froyo Jan 31, 2017
