8
Bluetooth issue on OnePlus 5T
  1. G_Aliyu_Abubakar_AXyS
    Cupcake Nov 28, 2017
    G_Aliyu_Abubakar_AXyS , Nov 28, 2017 :
    My OnePlus 5T is unable to detect my wireless headphones. I refreshed many times but it's still not finding my headphones. What can I do?
    SymDR, jbannink, der.hias and 5 others like this.
  2. the_reckoner
    Ice Cream Sandwich Nov 29, 2017
  3. G_606amin_DHOZ
    Cupcake Nov 29, 2017
    antidanis likes this.
  4. Shawnlane
    Froyo Nov 29, 2017
    Shawnlane , Nov 29, 2017 :
    I was having all kinds of Bluetooth issues. I went to Settings/Advanced/Bluetooth Audio Codec and selected aptX HD. Then I rebooted the phone and everything was fine with Bluetooth. I hope it works for you.
    antidanis and G_Tim_Matlock_umXj like this.
  5. determinator
    mipan78 likes this.
  6. Xgor
    Xgor , Nov 29, 2017 :
    For me it's a constant lagging issue with the sound, doesnt matter what codec ord sound soruce...my new wh-1000xm2 works better with my last OP3 than my new OP5T...that's sad.
  7. determinator
    determinator , Nov 29, 2017 :
    Yes, latency in BT is also a problem big time! You can tell if you watch a video: lipsync is way off!
  8. G_Aliyu_Abubakar_AXyS
    Cupcake Nov 30, 2017
    G_Aliyu_Abubakar_AXyS , Nov 30, 2017 :
    I appreciate your help. Unfortunately, it didn't fix the issue.
  9. G_Aliyu_Abubakar_AXyS
  10. William_Doyle_
    Cupcake Jan 4, 2018
    William_Doyle_ , Jan 4, 2018 :
    I also can't connect with any of my wireless headphones. Is this a common problem with the OnePlus 5t? Phone is only a week old is worth sending it back?
    RoySchreurs likes this.
  11. Tjayb
    Cupcake Jan 17, 2018
    Tjayb , Jan 17, 2018 :
    Hi,
    I experienced the same. Like others here, rebooting my 5T seemed to fix the issue. Although there does need to be a longer term fix.
    For anyone who needs to try the same you can reboot by:
    Pressing power off
    Once the device is off, you then need to press power on and the volume down button for a few seconds.
    Then enter your password and select the option to reboot
  12. IvanPatrick
    Eclair Jan 17, 2018
    IvanPatrick , Jan 17, 2018 :
    What I did in my case was I forget my bluetooth headphone in my OP5T and reconnect it again.
  13. ngajjar84
    Cupcake Jan 22, 2018
    ngajjar84 , Jan 22, 2018 :
    My OnePlus 5T won't connect directly to my Subaru Forester Bluetooth. I have to connect it manually each and every time. What's worse is phone call connectivity. The voice and connection is really bad. This never happens with any other phone that I connect my car with. Please help.
  14. dankozlowski
    Cupcake Jan 25, 2018
    dankozlowski , Jan 25, 2018 :
    I'm having the issue where my 5t can't see any bluetooth devices now. It saw a ton at first, but once I toggled BT it lost off of them. I can confirm that restarting the device seems to have resolved the issue.
    Shubham_Karvande_ and antidanis like this.
  15. elsbroos
    elsbroos , Jan 25, 2018 :
    I was told you try a soft reset for fixing my bluetooth problem, dies anyone know how you do this on a T5? Orde is a hard reset(I think as explained earlier) the only option?
    Thanks!
  16. Eadmond
    Cupcake Jan 31, 2018
    Eadmond , Jan 31, 2018 :
    I am having the same problem here. Can't connect my car through BT.
    There is a message telling me pin was wrong, while no keyboard pop out for me to input anything.
  17. G_Maria_Mertensacker_wzO
  18. Eadmond
    Cupcake Feb 1, 2018
  19. Arty Chas
    Cupcake Feb 1, 2018
    Arty Chas , Feb 1, 2018 :
    Good afternoon,
    Indeed, OnePlus 5T potentially may have some software issues with regards to Bluetooth.
    Although it connects flawlessly, latency in first 5 minutes is unbearable on a distance of less than a meter. Closing processes, reconnecting Bluetooth, changing codec do not solve the issue, unfortunately. Reboot works, but a bit of inconvenience most of the time.
    Issue existed with all Bluetooth audio systems, including two headsets and two car audio systems.
  20. N1516855723481
    Eclair Feb 1, 2018
    N1516855723481 , Feb 1, 2018 :
    Weird. I don't encounter this kind of problem.Mine connect automatically everytime I turn on my wireless headset. For me it's effortless.
