9
Bluetooth issue on OnePlus 6
  1. AADITHYA_KRISHNAN
    Eclair May 23, 2018
    AADITHYA_KRISHNAN , May 23, 2018 :
    Is it just me or anyone else have problems with Bluetooth. It just takes so long to identify a device and connect to it
    UPDATE:
    just few minutes ago OnePlus pushed an update that fixed the issue
    DrJMun, JamesRider21, Raresch and 6 others like this.
  2. timmmeeehhh
    Cupcake May 23, 2018
  3. laxmikant.b2
    Eclair May 23, 2018
    yuva_cool likes this.
  4. MentalDraco
    Marshmallow May 23, 2018
    MentalDraco , May 23, 2018 :
    Probably under developer options.
    love1plus1specs likes this.
  5. timmmeeehhh
    timmmeeehhh , May 23, 2018 :
    where would that be? it's not in the advanced menu
  6. kamal.kantech
    Eclair May 23, 2018
    kamal.kantech , May 23, 2018 :
    as far as Bluetooth is concern, I haven't faced any issue like that it can easily recognise devices and connect it. has tried to different piece of bluetooth all worked well.
    AADITHYA_KRISHNAN likes this.
  7. MentalDraco
  8. timmmeeehhh
  9. shaazzaarr
    Froyo May 23, 2018
    shaazzaarr , May 23, 2018 :
    I had a similar issue when connecting to my ford focus via SYNC. The phone wouldn't detect anything...after a while it showed up in the list. Very strange.
    it's now connected and working without any issues.
  10. M1527080376090
    MANISHpuri likes this.
  11. Sritejkadiveti
    Froyo May 23, 2018
    Sritejkadiveti , May 23, 2018 :
    it is present in developer options "Bluetooth audio codec"
  12. doris.bleyer
    Cupcake May 26, 2018
    doris.bleyer , May 26, 2018 :
    I also cannot connect to my Bluetooth speakers. It searches for devices but does not find them. And I have the latest version installed. Any suggestions what I can do?
  13. timmmeeehhh
    timmmeeehhh , May 26, 2018 :
    you sure your Bluetooth devices are in pairing mode? With my headset I have to keep the Bluetooth button pressed for a few seconds to enter pairing mode
  14. doris.bleyer
    Cupcake May 27, 2018
  15. Uthrakumarsengunthar
    Cupcake May 28, 2018
    Uthrakumarsengunthar , May 28, 2018 :
    My one plus 6 bluetooth is not getting connected to my Honda city car.It is not even reading the car Bluetooth device.All other phones are getting connected.
    Can anyone help
  16. Uthrakumarsengunthar
    Cupcake May 29, 2018
    Uthrakumarsengunthar , May 29, 2018 :
    Now I'm able to connect to my car Bluetooth device. I followed this- go to 1) settings 2) storage and memory 3) apps 4)Bluetooth 5) clear cache and then go to1) backup and reset 2)network setting 3)reset network setting and then switch off the phone and switch on.Delete anyother bluetooth device from your car Bluetooth speaker now try to connect the mobile
  17. MANISHpuri
    MANISHpuri , May 29, 2018 :
    Same issue with my polo too. It connects in jiffy but am not able to use it, neither while m as king calls nor while receiving calls. My car Bluetooth works fine with my 3 other phones.
  18. V1527617468841
  19. ananth2004
    Donut May 29, 2018
    ananth2004 , May 29, 2018 :
    I could connect to my Nissan Rogue's Bluetooth but the problem is that when I call or get a call it goes to the phone. Even from the phone if I choose Bluetooth when connected, it is not getting connected to the car's Bluetooth. I have tried like pressing the handset icon twice on the car's touch dashboard and then the call got transferred to the Bluetooth. But it is certainly annoying.
  20. SMEMC
    Cupcake May 30, 2018
    SMEMC , May 30, 2018 :
    I have the same problem as ananth2004, but my car does not have the option to touch the dash to make it to go to the Bluetooth. I had Oneplus 3 and it worked perfectly fine with it.
