9
Bluetooth issue on OnePlus 6
  1. darkthanatos
    Cupcake Nov 1, 2018
    darkthanatos , Nov 1, 2018 :
    Hi guys.
    I use OnePlus6 since September and I must say it is the best smartphone I've ever had alongside OP3.
    I know, of course, it is not perfect and has some annoying issues so that's what brought me here.
    I use OP6 with Android 8.1 and I've having issues with Bluetooth since I got the device.
    I been using Macrodroid to help me but it didn't fix the problem.
    The problem I've been having till now is every time the screen gets locked the Bluetooth turns off (if I am using it in that moment)
    It seems the OS closes the mostly second activities running is the device when the screen gets locked (I have all Battery Saving disabled). Just doing this the problem is fixed (you must have the Developer options activated, Developer -> Apps -> Turn On "Don't keep activities")
    So "problem" is solved.
    #41
  2. S1541014998844
    Cupcake Nov 8, 2018
    #42
  3. G_Tomas_Ortiz_Lara_JUDR
    Cupcake Nov 8, 2018
    #43
  4. F1555473320188
    Cupcake Jul 3, 2019
    F1555473320188 , Jul 3, 2019 :
    I'm having a similar issue. I drive for a local shuttle company. In order to keep track of our driving hour and electronic logs, we use the JJ Keller app and devices. I can pair and connect, via bluetooth, without problems, however, after about 5 minutes, or so, my phone disconnects from the device, resulting in fragmented logs. Is there a way I can force my phone to stay connected to the JJ Keller device? I have enabled developer options, but I do not see any options that seem to make sense, that fit my situation.
    #44
  5. L1577335231974
    Cupcake Dec 26, 2019
    L1577335231974 , Dec 26, 2019 :
    Hi all I am not able to connect my jbl reflect mini 2 Bluetooth earphone with my 6t , the device simply does not show in the pair new device list. I tried all the steps mentioned above but still no use. Please suggest
    #45
  6. U1575007411621
    Cupcake Feb 3, 2020
    #46
  7. Caomhin
    KitKat Feb 3, 2020
    Caomhin , via OnePlus 6T , Feb 3, 2020 :
    Update to 10.3.1 via OTA or Oxygen Updater from the Playstore.
    If you still have issues reset your WiFi.
    Settings, System, Reset Options, Reset WiFi
    #47
    DrJMun and Kytharsis like this.
