Bluetooth Issue with Android 9
  1. Dr Vipul Dutt Froyo Sep 24, 2018
    Dr Vipul Dutt, Sep 24, 2018 :
    After update to Android 9 on my OP6, previously flawlessly working smartwatch and Bluetooth headphones are malfunctioning. Smartwatch is not showing call notification and headphones are not getting call outputs, whereas still working fine for listening music. Strange. Shall I change some settings. Kindly guide
    axelgrease15 likes this.
  2. Mohan+ Eclair Sep 24, 2018
    Mohan+, Sep 24, 2018 :
    Yes... I am not able to connect my fitbit charge 2 after pie update
    Pheak and Anurag_Shrivastav like this.
  3. TomasIceland Cupcake Sep 24, 2018
  4. B_Wrath Marshmallow Sep 24, 2018
    B_Wrath, Sep 24, 2018 :
    Unpair your devices.. Again pair them using the respective applications.
  5. Dr Vipul Dutt Froyo Sep 24, 2018
    sir done but not working
  6. p_martins Cupcake Sep 24, 2018
    p_martins, Sep 24, 2018 :
    Same here. My garmin vivoactive3 is also not pairing. Unpair and pair doesn't work. The phone does not even recognize the watch. On another phone immediately recognizes.
  7. bjorg18 Gingerbread Sep 24, 2018
  8. MichaelMeyers Cupcake Sep 24, 2018
    MichaelMeyers, Sep 24, 2018 :
    Same problem here.
    I solved it by deleting the cash from my Bluetooth service in app settings.
    In the apps list you need to enable the system apps in order to see them.
    See screenshot
  9. Ravi 2244 Froyo Sep 24, 2018
  10. Paul D. Cupcake Sep 24, 2018
    Paul D., Sep 24, 2018 :
    Hi,
    I try to do that but it doesn't work.
    I still have problem to connect my Garmin Fénix 5 to my Phone.
    My watch give the secret number to connect at phone, but the phone doesn't see my watch.
    My last sync was the 22th september but after upgrade in pie no other sync and i have 2 activities to synchronise.
    Edit : Ok that work but i reactive the research when the BT is off (sorry i don't know in english)
    Sécurity & Lock Screen > Location > Scanning > Bluetooth Scannong "ON"
  11. saad1957 Jelly Bean Sep 24, 2018
    saad1957, Sep 24, 2018 :
    - settings >> apps & notifications >> all apps >> 3 dots ( show system apps ) >> Bluetooth >> storage >> clear data and cache
    - settings >> system >> reset options >> Reset Wi-Fi, mobile & Bluetooth
    reset
  12. Chinaroad Gingerbread Sep 24, 2018
    Chinaroad, Sep 24, 2018 :
    The blutooth issue i have is latency when i play pubg or when i use video calls, but on youtube i don't have latency
  13. bulubuluplopplop Cupcake Oct 1, 2018
    bulubuluplopplop, Oct 1, 2018 :
    made all that, still no connection.
    My watch says it's allready connected, it's listed in my bluetooth devices on my phone, but not recognized by garmin connect and no sync...
  14. B_Wrath Marshmallow Oct 1, 2018
    B_Wrath, Oct 1, 2018 :
    Remove the watch from pairing in bluetooth settings... Re pair it using the app ..
  15. bulubuluplopplop Cupcake Oct 1, 2018
  16. Luke2002 Cupcake Oct 1, 2018
    Luke2002, Oct 1, 2018 :
    the Bettery with pie became awesome
  17. nfvillamil Cupcake Oct 1, 2018
    nfvillamil, Oct 1, 2018 :
    Hello all, I am having an issue with my Bluetooth connection ever since the upgrade to Android 9. It goes off while it's connected to my car and at the same time I can't connect it to my smart watch. I'm guessing I'm not the only facing the issues. My Bluetooth has been crashing too many times for my liking. Please advise!
  18. getinet Cupcake Dec 14, 2018
    getinet, Dec 14, 2018 :
    I had connectivity issues with Wi-Fi and Bluetooth after the latest Pie Update (A5000_23_181205) on OnePlus5.
    My solution was to …
    Settings > System > Rest Options > Reset Wi-Fi, Mobile & Bluetooth > Reset Settings > PIN and Confirm
    Reboot
    Hope this helps.
  19. O1544630530333 Cupcake Dec 20, 2018
    O1544630530333, Dec 20, 2018 :
    Hi folks , I'm trying to pair my BT ear buds it's a new phone nothing has been paired but all I get is the swirl of death .
    Wondering if the issue is a older platform from the ear buds ? If so I figured the BT would backwards compatible.
    Thanks for any insight
    oops the insight was my stupidity I mistook the wrong mode on the earbuds all good ,my bad [e]1f601[/e]
    Kytharsis likes this.
  20. Akhshay Srinivasan Nougat Dec 21, 2018
    Akhshay Srinivasan, Dec 21, 2018 :
    Hi Dr. ,
    Could make out from your post that your BT option isn't working fine. This jam might be because of multi smart technologies being handled from a single device (your phone).
    No worries !
    Request you to do the following for better results :
    > Switch off your device
    > Hold power & volume buttons down
    > Enter password
    > Choose English (preferable)
    > Choose wiping data & cache
    > Choose wiping and NOT DATA
    > Confirm "Yes"
    > Reboot your device now
    > Go to settings > storage and memory
    > Choose cached data (at the bottom)
    > Click 'Ok' to clear off cached data
    P.S. : This will clear the hidden caches which act as junks in your device completely but your files or folders remains safe.
    The above process will indefinitely solve your BT issue but if the issue persists still, submit your bug here.
    Thank you :)
